**Need Help setting up V7???** Here is your answer
Old Jul 15, 2012 | 05:28 AM
  #466
FATDAT7's Avatar
Cheers Luca, Thanks for your help
Old Jul 15, 2012 | 01:00 PM
  #467
luca1989's Avatar
There's a mistake
I don't know how to change those bits and my Evo doesn't start if I copy only the immo code
Old Jul 16, 2012 | 02:23 AM
  #468
ddb's Avatar
ddb
Originally Posted by zoek24
ok so I'm starting to think that the Rom 94171715 (v7 + Mods + Speed Density Omni 4 Bar) Is flawed in some way. I'm needing to edit the MUT12 cell. This cell currently is in a column with nothing but FFFF. This seemed off to me so I looked at the MUT table in some other ROMs and found that they looked much different. For one they are twice the size and ever other column the (ones Filled with FFFF) are labeled as "-" and the others are numbered. If somebody could look into to this I would really appreciate it. This is the only thing keeping me from getting up and running
I'd like to know the answer to this also... i'm trying to run the wideband in the ecu but i have the same thing in my rom for mut12. Can someone help me please.
Old Aug 9, 2012 | 08:25 PM
  #469
tjac357's Avatar
I'm having some issues setting v7 up. My rom id is 88590015. My car is on the stock bc solenoid and is mostly stock except intake and tbe. The issues I'm having are with the following tables and what i set them at:
WGDC 100% under this load
MAF IAT WGDC Correction
TPS WGDC Correction
Trying to get the rom set up so i can run v7. or if there are any other things i need to worry about. thanks
Old Aug 12, 2012 | 09:52 AM
  #470
211Ratsbud's Avatar
I can't get boost error correction to make adjustments to my bwgdc . Set up for psi and all maps adjusted for omni4bar. Any thoughts?
Old Aug 14, 2012 | 07:03 AM
  #471
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Sorry if this was already addressed but does ROM 96530706 been modded for the OMNI 4 Bar map sensor?
Old Aug 17, 2012 | 09:35 AM
  #472
TheBigD's Avatar
hello, i have rom 94170008, when i open up a rom file of mine, it is missing little things here and there, like there's a big hole in my Asynch_TPS(rpm) limit, SD MAT scaling for IAT scaling table is blank...and ect. BUT the thing is my car starts. but wont stay running on its own, and also its so rich that it shoots un burnt fuel out the exhaust....and no matter how much i rape the SD map ve and the SD RPM ve and the main fuel and timing table it doesn't make a difference... and i cant find in the SD what is causing this problem, ive done everything the thread says to do, tried re downloading. still nothing. help would be greatly appreciated!
and also am i supposed to disable the SD disable MAF error main? since your not using it? i didnt.. but i dunno what to try anymore, cant figure this out, no matter what i change it doesnt make it run any better
Old Oct 7, 2012 | 07:57 AM
  #473
AutoXer's Avatar
I'm in need of a bit of help. I have two issues.
1. RPM hang/rise after throttle lift. I've looked for mechanical issues (vacuum leak, sticky throttle, etc.), but I can't find anything. I also can't find any definitive answer about which tables to alter. I keep finding conflicting information. I don't want to monkey with a table unless I'm sure what it does.
2. When coming off of boost, I can hear 5-6 fast suscessive clicks. It does it every time the the boost gauge needle falls below atmospheric pressure (0psig). I can't see any other issues related to the clicking, but it drives me nuts! My suspicion is that it's either the boost control solenoid (Grimm Speed) or something to do with the EGR and my periphery bits. I am running the pressure based boost control.
Can someone take a look for me? The ROM is attached.
Old Oct 8, 2012 | 12:21 PM
  #474
mdost03's Avatar
I found out I have this issue this weekend when shifting at WOT at higher RPM's. I am on v5.10 still though, but would be interested to see what kind of answers people have on this.
Old Oct 9, 2012 | 04:02 AM
  #475
AutoXer's Avatar
I'd be willing to issue a small PayPal payment to whoever helps me solve these two issues.
Old Oct 9, 2012 | 04:51 AM
  #476
And's Avatar
And
a few comments
what happens if you zero out your Decal fuel cut Retard,
you also haven't applied the patch to enable rpm limits
do you have EGR on your car?
Old Oct 9, 2012 | 05:18 AM
  #477
AutoXer's Avatar
I haven't tried it because I'm not sure what the tables do. While reading the threads, I find conflicting information about what the tables actually do and the correct way to fix the problem. I'm away from my tuning PC at the moment, so I can't post up screen shots to make sure it's the right table.
You lost me there. What patch for RPM limits? Decel fuel cut RPM limits?
Yes. It's all still there.
Thanks for the reply!
Old Oct 9, 2012 | 05:32 AM
  #478
And's Avatar
And
add this to your xml
Code:
	<table name="code chg srev test" category="Limits" address="129c0" type="2D" level="1" scaling="Hex16">
		<table name="code all 0009 except last which should be 3ab6" type="Static X Axis" elements="13">
			<data>3ab6</data>
			<data>8b03</data>
			<data>da37</data>
			<data>6aa1</data>
			<data>db37</data>
			<data>2ba1</data>
			<data>da36</data>
			<data>6aa1</data>
			<data>2aa8</data>
			<data>8b11</data>
			<data>d035</data>
			<data>6001</data>
			<data>c801</data>
		</table>
	</table>
and this is the table as was on about zeroing
Code:
	<table name="Decel Fuel Cut Retard" category="Fuel" address="4312" type="2D" level="2" scaling="Timing">
		<table name="Engine Speed" address="6576" type="X Axis" elements="10" scaling="RPM"/>
	</table>
Old Oct 9, 2012 | 08:03 AM
  #479
mdost03's Avatar
Is there a thread with more information about the patch? Just curious about finding out what it all does.
Old Oct 9, 2012 | 08:18 AM
  #480
And's Avatar
And
you'll have to search for the post but it to enable the stationary rev limiters as you'll be able to rev to "infinity and beyond" otherwise
Andy
