**Need Help setting up V7???** Here is your answer
Stunt, the load factor matters for logging purposes as it takes 2-byte and divides it by the factor in the rom, and then evoscan multiplies the 1byte by that factor to show load.
noobers, are you using the base 9417 V7 or would ou by chance accidentally using one setup for the omni 4-bar? Have you tried using the other VIII V7 rom?
Sorry for the noob question but I need help logging the following and I have tried searching with no luck. I want to:
1 Log the airflow calcs (lbamin)
2 log IAT with the GM sensor
I have been running the V7 ROM since it came out but I decided to dig back into this stuff and try to start tuning again. It seems most of the patches were written prior to the V7 release.
I have enabled the Tephra Mod options in the ROM, and followed the Evoscan directions for setting up the logging. Do I need to patch the V7 ROM to be able log these or are the V7 ROMs preloaded with all the necessary settings?
Logging the IAT returns in a steady 195.8 F
Logging the Airflow returns a 0
Thanks in advance for your help!
Tryin to read my ecu with ecuflash. Downloaded tephra v7, an copied all into rom data folder. Still won't allow me to utiliZe ecuflash. I did a golden evo scan and it came back with rom Id 52690122. I Didnt see that in the folder anywhere. Is it not supported by v7? Previously tuned car btw, just looking to view and edit some tables
08 evo x mr
08 evo x mr
so i'm confused. i've seen people say they are waiting for 88590015 for usdm evo IX and then others are saying they are using 88590715. help me out with this please. if it does work then how step by step can i make this happen? this is really kicking my butt...
Try this. If you still need help pm me and I can assist you in setting this up with your current rom.
https://www.evolutionm.net/forums/ev...hramod-v7.html
I've downloaded V7, copied maps over, tweaked settings, and added scaling/latency for my new injectors. I also went through each item in V7 to see what it was trying to control. After all of this, I have the following questions and would be grateful to hear some answers.
1) V7 now shows I have a 6-speed instead of a 5-speed. The How-To for V7 shows only using gears 0-5 so I'm guessing I'll be okay. When in gear based boost control how does it know what gear I'm in?
2) Under "Idle" settings my "High Intake Air Temp ISCV Increase" table has changed. Why?
AC OFF - Old = 17, V7 = 0
AC ON - Old = 42, V7 = 17
3) I added a MUT table to my last ROM. I assume I don't need to copy anything from this over to V7, is this true?
4) Under "MAP Sensor" the "MAP Test 1: Mid VE Max Voltage" went from 4.90 to 4.80. I understand it's small, does it matter?
5) Under "Global Boost Control Settings" what is the "RPM/Speed to Gear" table? Do I need to change anything? Sort of goes along with question 1.
6) Under "Global Fuel" what is the "Fuel Cut Multiplier"? Do I want to use x1 or x2?
7) What's the point of "MrFred Airflow Calcs"?
Thanks in advance for any and all help. I'm pumped to start using V7 but I'd like to make sure it's set up correctly first.
1) V7 now shows I have a 6-speed instead of a 5-speed. The How-To for V7 shows only using gears 0-5 so I'm guessing I'll be okay. When in gear based boost control how does it know what gear I'm in? You will be fine with just using 0-5. Most folks just copy their 5th gear settings into the 6th gear column. The ecu determines the gear through speed and rpm.
I can't tell you why on this one, but it did not impact me.
4) Under "MAP Sensor" the "MAP Test 1: Mid VE Max Voltage" went from 4.90 to 4.80. I understand it's small, does it matter? 4.90 is for the stock mdp sensor, 4.8 is for an Omni 4-bar. Set yours up according to which one you have.
5) Under "Global Boost Control Settings" what is the "RPM/Speed to Gear" table? Do I need to change anything? Sort of goes along with question 1. This impacts your gear based boost control. Do not change.
6) Under "Global Fuel" what is the "Fuel Cut Multiplier"? Do I want to use x1 or x2? Use fuel cut x1 if your load curve is under 319, use fuel cut x2 if your load curve exceeds 319.
Thanks to ReaperX questions 1, 4, 5, and 6 are answered. I looked up in the Omni 4bar thread and for some reason it changes between 4.80V and 4.90V on different ROMs for the Mid VE Max. I'm going to use 4.90 as that's what 94170015 calls for.
Still waiting for 2, 3, and 7.
An honest thank you goes out to all the people involved in coding, testing, troubleshooting, and advising for V7.
I'm running the v7 ix by recompile without speed density. I'm looking for the boost cut table. I don't see it. My 1 byte load goes to 355. I don't see the boost cut table in the rom. I only see the fuel cut 2x for my situation. I've done some searching, but can't find the information I need.
1. Will the boost cut work since my load is higher than 319?
2. If yes to number 1, what xml tables do I add?
