**Need Help setting up V7???** Here is your answer
Old Jan 2, 2011 | 09:20 AM
  #331
BoostedFury's Avatar
Ecu Flash 1.42
converting from 96940011 to Tephra V7 96530706
I copied over all my stock replacement maps (base wg duty, boost desired eng. load, high/low oct, high/low ign map, and the immobilizer)
I checked my injector scaling, voltage, and base vs. the 96530706 and it was the same.
My questions are:
I found the open loop load 1/2, throttle 1/2, and lean spools are different in my 96940011 from the new rom 96530706. Should I be changing these values to be identical to my 96940011 info?
Also, what other sections should I be changing over?
Do I need to change ecu external id to match my old rom as well?
Old Jan 12, 2011 | 04:20 PM
  #332
SWOLN's Avatar
88590715 : seems like I've hit a snag. I haven't logged this yet, but would there be some reason why I'm hitting ignition cut at 28.0 psi ? I know it's not the plugs I've changed them and the same quick dat, dat, dat, dat,... occurs at 28 psi. Thanks in advance
different thing same ROM, Is there any reason why I can't see the rpm drop box on the NLTS?
Old Jan 13, 2011 | 12:16 AM
  #333
And's Avatar
And
what are you max loads set too and what loads are you seeing?
Old Jan 13, 2011 | 05:45 AM
  #334
SWOLN's Avatar
Seems like at 26 psi I'm hitting 280-290 load, but I haven't logged this phenomena.
Old Jan 14, 2011 | 04:39 AM
  #335
Fast_Freddie's Avatar
Veteran: Navy
I had a glitch with NLTS patch on my car a while back and it was doing the same thing... disable it in tephra options and see if that cures the issue... I never figured out what the problem was with it and never used NLTS again...
Old Jan 14, 2011 | 04:44 AM
  #336
Appauldd's Avatar
SWOLN and Freddie....I hit the same thing. Thus my post about cutting out. WTF is it ? ? ?
Old Jan 14, 2011 | 04:48 AM
  #337
Veteran: Navy
No clue, it is like NLTS code gets screwy and uses like an RPM switch activation instead of the clutch switch or something...as I had logs of it and it happened at the same RPM going from 2nd to 3rd only... it happened to me at the track and it took me a few days to track it down... I swore it was mechanical... nope was the NLTS...
Old Jan 14, 2011 | 05:04 AM
  #338
Appauldd's Avatar
That is exactly what I found....like an RPM cut. Funny thing is I disabled the NLTS and the condition has stuck around for me. I know it has to be in the code somewhere.
GRRRR.
Good thing my car is sitting for year while I play Army in the land of sand.
Old Jan 14, 2011 | 06:02 AM
  #339
Veteran: Navy
Yeah it stuck around for me as well, I flashed a fresh ROM with NLTS disabled off the get go and that is how I got it to go away...
Old Jan 14, 2011 | 07:10 AM
  #340
HornstarBU's Avatar
Are you guys making sure you let the clutch pedal all the way out? If you hover your foot on the pedal even just a slight bit, it can stay in "rev limited" mode or whatever, so you gotta make sure it's all the way out.
Old Jan 14, 2011 | 07:50 AM
  #341
Veteran: Navy
Yes clutch all the way out and foot not on the clutch... I am talking like 6500-7000 RPM in 2nd gear when this happened...
Old Jan 14, 2011 | 08:35 AM
  #342
SWOLN's Avatar
Please post the thread, I looked and couldn't find it in Ecuflash.
.and this has nothing to do with the clutch switch as far as I know because when it happened I was ***** out in 5th gear.
Also may have popped the motor, start up is aweful with excessive popping in the exhaust, and EGT's are not coming up to temp correctly now either.
Old Jan 14, 2011 | 10:54 AM
  #343
Veteran: Navy
SWOLN, try flashing a fresh ROM on there with NLTS disabled off the get and see if that helps...
Old Jan 14, 2011 | 11:20 AM
  #344
SWOLN's Avatar
Yeah, when I get home I'll give it a shot... I'm going back to a previous one that ran well for quite a while.
Old Jan 14, 2011 | 05:40 PM
  #345
Ecu Flash 1.42
My questions are:
