**Need Help setting up V7???** Here is your answer
Old Aug 31, 2010 | 10:57 PM
  #286
gallas's Avatar
ok im trying to figure out how to convert over to this mod from my current tune. I am in the process of moving every piece of data over to the V7. when i got to the fuel maps, i noticed that the V7 has no high oc or low oc maps?? any idea why. im new to tuning, sorry.
Old Sep 1, 2010 | 10:57 PM
  #287
D-VO's Avatar
There's two fuel sections gallas. There's Global Fuel Settings and Main Map Fuel Settings. Are you missing the tables from the Main Map Fuel settings section?
Old Sep 1, 2010 | 11:46 PM
  #288
gallas's Avatar
yeah i found where they were at. my new problem is that when i transfer all the data to the V7 rom and save it, then go and close the rom and re open it. the rom opens as a normal stock rom without the v7 dropdown. i found if i only change a few things like immobilizer code and such it will save fine. but if i change the timing for example, when it is opened again after the save its back to stock rom setup... i have literally transfered my current tune to the V7 over a dozen times..
Old Sep 2, 2010 | 04:01 PM
  #289
Tonba's Avatar
HELP!
Im currently running 96530706 on my JDM evo 8 GSR.
The problem that Im getting, Is my car randomly throws up a o2 sensor code. This cant be right as I have a brand new sensor. had this issue before, but it was also throwing up an o2 heater circuit code. After we changed the o2 sensor we only get the o2 sensor circuit fault code. Its totally random when it desides to light up.
I have heard that the only real difference between the Evo 8GSR & Evo 8 MR is a single pin to the ECU that relates to the o2 sensor. Has anyone else got some insight or information to this? HELP ME! I wanna get rid of how this code appears..
Cheers
Old Sep 2, 2010 | 05:17 PM
  #290
gsrboi80's Avatar
Originally Posted by Tonba
HELP!
Cheers
No too familiar with the JDM ROMs. Post up a screen capture of you PBITS could be something missed man. Primary or O2 Secondary O2????
Old Sep 3, 2010 | 03:12 PM
  #291
Benja's Avatar
Hey bro,
Try disabling FCA Pbits (2) bit.9, change to 0, this is for P0400 error i've been gettign lately.
Old Sep 3, 2010 | 05:57 PM
  #292
EvoLutionized8's Avatar
Hey guys ive been searching for ever. Can anyone please post or send me the link for setting up the 3.5bar aem sensor for sd.... thanks much guys.....
Old Sep 9, 2010 | 05:49 PM
  #293
malac0da13's Avatar
I just want to make sure what I am doing is right. I downloaded the mod put three xml in the metadata folder and put the rom where my rom's are. Then when I opened the run that was downloaded it asked me to convert it or something (not sure if I did it right because for some reason the year is wrong and I don't have a 6sp). From here I just copy my values from my rom to the one I downloaded?
Old Sep 9, 2010 | 11:52 PM
  #294
And's Avatar
And
the year and 6sp are just defined in the main xml (96530706 if your using that one), you can edit them if you want to be more specific to your car but it doesn't really matter
Old Sep 24, 2010 | 12:03 PM
  #295
rgar's Avatar
I'm using the 88590015v7 rom and I notice that while logging, I have 0% wgdc all the way through 100 load. Is this normal or am I missing a setting somewhere?
Thanks,
Old Sep 24, 2010 | 01:34 PM
  #296
kaj's Avatar
kaj
Thanks,
Any load below 100 is vacuum so that would be correct.
Old Sep 26, 2010 | 07:16 PM
  #297
Chino1's Avatar
started setting up v7 and didnt have much luck. transfered everything i could find in my old map over to the new one. my current rom is 88590015 running speed density. i downloaded the modded rom from the v7 thread 88591715 and when i crank up the car the idle is more lean than the wideband can display. i dont have my wideband setup for looging yet. also, idle related, it didnt want to stay on at first but once i let it warm up it stayed on but stayed pretty lean, around 16-17 afr's.
thoughts?
Old Sep 27, 2010 | 04:44 AM
  #298
Chino1's Avatar
would this have anything to do with it?
Old Oct 4, 2010 | 04:13 PM
  #299
gallas's Avatar
does anyone know of any bugs in the rom for 88590015... i have a thread on my problems and have been reseracing daily for so damn long... the tephra v7 rom works and runs fine... the first time.. i know its not immobilizer related but just random as hell.. i will flash the v7 rom starts up great, drives great. but as soon as i turn the ignition off the car acts like the fuel pump is off next time i try to start. sometimes i can flash it and start it 10, 3 or 2 times in a row before it stops. i have looked every where and talked to countless tuners... im bout ready to throw in the towl and call this crap.. does anyone even have a clue??
Old Oct 4, 2010 | 04:16 PM
  #300
gallas's Avatar
i noticed the same thing when i got to those tables. all i did was take the equations and setting in from the old rom when u go to edit data and transfered it over to the v7.
