**Need Help setting up V7???** Here is your answer
Old Jan 25, 2010 | 11:03 AM
  #136
MSP608's Avatar
Originally Posted by MSP608
So I have a couple issues. My stationary rev limiter doesn't work.
I don't have a value for NLTS RPM drop (just displays a small gray box) and can not change it. Also, I assume the NTLS Speed and Load thresholds should be adjusted? I mean if I'm reading this right, I'd have to be under 19 mph and 150 load to get NLTS to work on the given settings.
Has no one else had these issues??
Old Jan 27, 2010 | 04:40 PM
  #137
chmodlf's Avatar
Can someone please post the addresses for 96530706 for:
raw 2byte load
baro compensated load
temp+baro comp load
EDIT Found Answer:
raw 2byte load - 898A, 898B
baro compensated load - 898E, 898F
temp+baro comp load - 8990, 8991
Old Feb 13, 2010 | 05:53 PM
  #138
knochgoon24's Avatar
Right now, I want to log IAT through the fuel temperature input (pin #77) on an evo 8 ecu. I'm currently running the 96530706 - "v7 Option 4" rom. Is there a version of this rom out there that already has the patch in place? I already have the IAT in my car and wired up. I just need to figure out what I need to do from here so I can log it. I want to make sure everything is setup and working correctly before I start making the switch to SD.
tl;dr - I need a 96530706 rom setup to read IAT through the fuel temp input. Either premade or directions to patch.
Old Feb 14, 2010 | 04:02 PM
  #139
liyellowevo8's Avatar
I keep getting like a over boost symptom I am going to read the code later to see if thats it. Do I have to change any boost settings to let it run the boost Im using?
Old Feb 14, 2010 | 11:52 PM
  #140
And's Avatar
And
its worth checking the load cut settings I think they are set around 230 ish in mode one and 460 in mode 2 worth checking your set up
Old Feb 15, 2010 | 07:05 AM
  #141
What should the load cut setting should be?
Old Feb 15, 2010 | 07:36 AM
  #142
And's Avatar
And
it depends on what mods etc you have etc and what load you expect normally, i'd say change the fuel cut multiplier in the global fuel settings to 4D00 then change the Fuel Cut load x2 to around 250 go from there. if you have quite a few mods you might need to change to a higher valve
Old Mar 11, 2010 | 09:31 AM
  #143
nocturnal005's Avatar
table error for non-continuous monitor availability patch?
Hey there,
Am porting over to V7 sometime this week.
In recompile's version of 88590715 I found that for "Non-continuous monitor availability patch part 2" that the default value is 0xEBFF instead of 0xEAFF. The note associated with the table states that 0xEAFF is the value required for forced PASS inspection. Also, in the thread for the standalone mod it is also listed as 0xEAFF
Is this an error in the table or is 0xEBFF the correct value to have in the table (if so, why?)
thanks,
Norman
Old Mar 11, 2010 | 11:45 AM
  #144
nonschlont's Avatar
Originally Posted by nocturnal005
Hey there,
thanks,
Norman
it doesnt come set "to pass" its just added to the rom, so you can set it "to pass"....
Old Mar 12, 2010 | 12:28 AM
  #145
And's Avatar
And
Hi All
I'm running the 96532706 rom and all has been going fine, over the weekend I pulled the FGR system off the car, but now it seems to just almost want to crank when cold, sometimes I can catch it and get it to start straight away, but this morning it just kept cranking, I'd crank for about a 3-4 seconds with it not starting then wait for about 30 secs and try again, it would almost start but then it would be the same, I was going to adjust the IPW cranking values to lower ones to see if that helps, but as it was fine before removing the EGR I was wondering if there was something else I need to do. I changed the periphery bits as per the guide.
Thanks
Andy
Old Mar 12, 2010 | 06:34 AM
  #146
cij911's Avatar
My car is a 2006 Evo IX MR ROM ID : 88590013. I would like to upgrade to v7, but don't see the appropriate ROM. Also, I will continue using MAF for now. Thanks!
Old Mar 12, 2010 | 07:18 AM
  #147
Fast_Freddie's Avatar
Veteran: Navy
Originally Posted by And
Hi All
Thanks
Andy
How did you disable the egr system, via periphery bits, or the EGR disable routine?
Old Mar 12, 2010 | 07:21 AM
  #148
Veteran: Navy
use the V7 for ROMID 88590015 you can find all the info HERE
Old Mar 12, 2010 | 07:40 AM
  #149
Nasty Evolution's Avatar
Has anyone else noticed random hanging revs even after reaching operating temp? A few times now I've pegged the throttle, pushed in the clutch and or hit the brake right after but the rpms stay up for a second or so, kinda scary when you're in traffic and the car wants to keep going.
Old Mar 12, 2010 | 11:32 AM
  #150
And's Avatar
And
hi yeah I did both, this is the address I got for the egr
<table name="EGR System Enable/Disable" category="Emissions EGR" address="1041" type="1D" level="2" scaling="uint8"/>
I'm assuming this is correct for the v7 rom and that it's already patched??
I have this set to 0 assuming that means disable should it be 1?
Thanks
Andy
