**Need Help setting up V7???** Here is your answer
Old Dec 25, 2009 | 08:09 AM
  #91
Fast_Freddie's Avatar
Veteran: Navy
Originally Posted by rdtech
Great! Thanks FastLFreddie!
Do me a favor, and report back to verify if the fuel trims still adjust with this patch please... I am sure it will, and it may have been covered in the other thread, but please report back here also...
Old Dec 28, 2009 | 02:16 PM
  #92
03blue's Avatar
Originally Posted by donour
Has anyone experienced lift-off knock on 96530706? I get a persistant knock in the 2500-3500 RPM range between at 70-110 load. Those are the cells for short shifting with 50+% throttle. I reduced timing several degeres around there and it helped only slightly.
I don't think it is a part rattling issue, but actual knock. I think timing changes have already hurt drivability and I really don't want to retard it any more if I can avoid it. I have LOTS of logs if anybody wants to see.
d
I too am having this problem, is there any fix for it? Or just raise the knock sensitivity? If that is the only fix can some one please tell me how to do it and how much to raise it? Also one more thing i have been trying to get me fuel trims zeroed. I have got the idle zeroed by using bat. voltage but the mids were still -12.446 so i add 12% to the injectors size and it did not change the mid they are still at -12% again any help would be great.
Old Dec 31, 2009 | 05:15 PM
  #93
SWOLN's Avatar
I decided to redownload <---(not a word ?)the tephra V7 and when I got down to the last section the info is screwed... What happened here ??
Attached Thumbnails **Need Help setting up V7???**  Here is your answer-capture-ecuflash.png
Old Jan 1, 2010 | 10:57 AM
  #94
Veteran: Navy
Swoln, the XML is jacked, make sure you delete the old V7 data before you place the new XML into the rommetadata folder...
Old Jan 1, 2010 | 11:43 AM
  #95
Appauldd's Avatar
What is wrong with the XML data ? ? ? Looks like just those addresses are wrong.
Old Jan 1, 2010 | 01:46 PM
  #96
SWOLN's Avatar
I upgraded to an Alienware M15x, so there is no old V7 romdata except for the .bin that I sent myself from my old computer... Are you saying I need to delete the old V7 and the new one will work?
Old Jan 1, 2010 | 02:12 PM
  #97
Veteran: Navy
Yes make sure there is only on V7 XML in the folder
Old Jan 1, 2010 | 04:12 PM
  #98
Keller's Avatar
Hi I'm running V7 on my edm 96530006 with gm map sensor (sensor I got from bay some Mickey mouse one but looks like GM no stickers tho) I had to run loom to ecu to plug it in map sensor (emd 8 dont have map sensor) I also rescale evo scan to read 0 Psi on engine off to 0.057315*x-14.5 which is odd already ;/ . My question is do I have to change the scaling in XML and do I have to change the XML to read scaling from GM3 bar be cos looks to me like is reading now scaling for JDM map sensor . Thx
Old Jan 1, 2010 | 04:15 PM
  #99
SWOLN's Avatar
Hmm, I dumped the original .bin in the recycle bin, and took a snapshot of the rometadata. Did I foul something up ?
Attached Thumbnails **Need Help setting up V7???**  Here is your answer-capture-ecuflash-2.png
Old Jan 1, 2010 | 04:41 PM
  #100
nothere's Avatar
SWOLN
I think its an incomplete file that not needed for normal / non sd cars
Old Jan 1, 2010 | 05:05 PM
  #101
SWOLN's Avatar
Originally Posted by nothere
SWOLN
I guess that's fine, but I am not a fan of second guessing what's going into the car, and my previous download had, what looked like, the correct data. I guess it makes me wonder what else is missing, or deleted by accident. Thanks to all who helped...
Old Jan 2, 2010 | 03:19 AM
  #102
Keller's Avatar
Hi I'm running V7 on my edm 96530006 with gm map sensor (sensor I got from bay some Mickey mouse one but looks like GM no stickers tho) I had to run loom to ecu to plug it in map sensor (emd 8 dont have map sensor) I also rescale evo scan to read 0 Psi on engine off to 0.057315*x-14.5 which is odd already ;/ . My question is do I have to change the scaling in XML for my gm 3 bar map sensor? and do I have to change the XML to read scaling from GM3 bar be cos looks to me like is reading now scaling for JDM map sensor ? Thx
Old Jan 3, 2010 | 02:30 AM
  #103
And's Avatar
And
I'm now running the v7 rom and all seems good, but I've copied the fuel and timing over from my standard rom but now I'm getting lots of knock and have started to reduce the timing to remove it, but I'm wondering if I've missed copying something else across? I've done the injector sizes and latencies etc. my wide band is reading around the 11.5 range.
At the moment I'm assuming that its just normal to experience this and that a remap is always going to be required. I'm also using the 1 byte load and not the ecuload is this correct?
Cheers
Andy
Old Jan 3, 2010 | 10:13 AM
  #104
Slo_crx1's Avatar
Previous versions of v.7 were done in "increments" so to speak, each different version of v.7 had add-on xml's that were used in conjunction with the stock 96530006 rom. Later releases combined all the xml's into one main version. Delete or remove any previous versions and use the new releases.
Cheers
Andy
Part of v.7 is the new "big maps", so make sure your maps are scaled properly to what your values are from your old map. It's not exactly a copy and paste setup anymore, so if these are off anywhere you could see the type of problems you're experiencing.
Old Jan 3, 2010 | 10:38 AM
  #105
nothere's Avatar
is the only thing wrong with SWOLN's data the wrong data name (Airflow...)?
