Trying to understand timing map
Old Feb 23, 2010 | 07:19 AM
  #106
Appauldd's Avatar
Originally Posted by ethan169
ive been searching on and off for a few days now. But im no t giving up yet!
Also if paul happens to come back to this thread I saw something he posted on another thread about "Idle Stability timing control" and posted this table
<table name="Idle Stability Timing Control" category="Timing" address="174e" type="2D" level="2" scaling="uint16">
<table name="Settings" type="Static X Axis" elements="3">
<data>Sensitivity</data>
<data>Timing Limit</data>
<data>Untested</data>
</table>
</table>
You were saying something about raising the sensitivity from the stock 128 to 146... My idle is a bit more unstable now compared to how it was with more timing at idle. Maybe I should change that back as well. It was at 14* idle and not its 10 to 8* at idle.....
-ethan
Your idle was mostly affected by lowering your timing. Did you change the idle RPM as well???
The Idle Stability Timing Control table does exactly what is say.... stabilizes idle. At first we thought that raising the value helped.....I have since discovered, as you have, that idle does suffer a little if it is raised. Thus, I leave it at 128. The second value in the table will help if you are getting big swings in idle timing. Lowering it will tighten up those swings.
Old Feb 23, 2010 | 07:21 AM
  #107
tscompusa2's Avatar
i see what i forgot to set ethan....... ecu periphery7 hex (under immobilizer) address 0xffa i believe. its set to 0055 and i think 0055 = 2004 and 2003 = 0040
Old Feb 23, 2010 | 07:27 AM
  #108
ethan169's Avatar
I noticed that. If I open up my stock ROM all of those blobits or bit or whatever they are, are 0040. Should just the 0xffa bit be changed to 0040 or all of them?
Also this is the stuff that Im talking about.. WHERE does it say how to do this? I mean this is the basics of how to setup the ROM for different cars so it MUST be discussed somewhere. If I understand whats going on with the changes that are made I feel more comfortable about making them. I dont like to do things "blind"
Thanks guys!
Old Feb 23, 2010 | 07:29 AM
  #109
tscompusa2's Avatar
i sent the edited rom to your email. how fast can you confirm the car fires up?
Old Feb 23, 2010 | 07:35 AM
  #110
ethan169's Avatar
I wont be able to try anything on the car till 12 but ill let you know for sure!
thanks
-Ethan
Old Feb 23, 2010 | 10:14 AM
  #111
tscompusa2's Avatar
thanks
-Ethan
so did it start? and did you read the forwarded email i sent regarding the changes i did with the immobilizer code in the periphery7?
Old Feb 23, 2010 | 10:24 AM
  #112
ethan169's Avatar
Its did start with the first one. (the one with only the one line changed) which was interesting because the ROM that paul sent me had all of those lines set to 0040.. and he is running with a 2003 as well it looks like.
Do you know where these ecu periphery's are defined?
Also the xml that paul gave me didnt have tables for the ECUPeriphery 7 interestingly enough. I havent tried his yet as the load tables are scalled to 320 and I didnt have time to put values in the 260-320 range.
side note: is there a certain number of times a ECU can be flashed? I wouldnt think so but I feel like a thread I read recently hinted at this...ideas? Thoughts?
Thanks
-Ethan
Old Feb 23, 2010 | 10:29 AM
  #113
Appauldd's Avatar
There was thoughts years ago that there was a limit.....but no, there isn't.
Old Feb 23, 2010 | 10:30 AM
  #114
tscompusa2's Avatar
Thanks
-Ethan
Because you only need to change address FFA thats why it started. Rescaling is easy to do, but just use the rom i sent since its scaled the same way the original tuner did it. i use up to 500 scaling on my big map rom and 360 on the v5 rom. Log some pulls when you get home and report back where the knock is here. And keep in mind lean spool is still enabled, because i feel the orig tuner never tampered with it, so i didnt want to effect your fuel map settings at this time.
an ecu can be flashed unlimited times.
Old Feb 23, 2010 | 10:34 AM
  #115
tscompusa2's Avatar
how is your v7 94170015 doing? in case i have issues with the 9653 one id like to know i have something to fall back on.
Old Feb 23, 2010 | 10:41 AM
  #116
ethan169's Avatar
Ive attached a log of a quick pull in 3rd. My office is in a very industrial area with a lot of other offices and I didnt want to create too much a scene outside running 3rd gear pulls up and down the main road.
So anyway knock is at max 3 counts during the 3rd gear pull.
Ive also attached a log of me driving back to work. you can see some of the weird knock readings that are out of boost and part throttle. see lines 1075,1614,1729
(I just graphed the knock sum and looked at where the high points were)
That 1075 has 14 counts on that one cell i think?
What do you think? Again this is still with the UTEC in I wont have that out of the equation till late tonight or tomorrow afternoon. Although the UTEC is on "bypass" mode (map 0).....
-Ethan
File Type: zip
Old Feb 23, 2010 | 10:48 AM
  #117
tscompusa2's Avatar
what are your fuel trims at? when i started my car yesturday it said 255 counts of knock lol at just idling, but my inj scaling is ****ed atm with the 2150cc. i got all my wiring pulled out and rerouting everything better. and setting up so i can log the aem serial.
Old Feb 23, 2010 | 11:00 AM
  #118
ethan169's Avatar
Im not sure what they are at. I guess Ill have to log them. I honestly dont know much about the fuel trims...Also I am on the stock injectors still...
Old Feb 23, 2010 | 11:09 AM
  #119
Appauldd's Avatar
I couldn't be happier with 9417 v7....it works flawlessly.
Old Feb 23, 2010 | 11:11 AM
  #120
Appauldd's Avatar
Ethan's car is almost stock. So, he is experiencing all of the common 03 stock problems. Tip in knock, rich as hell up top, p0300 etc.
We will get him fixed up. Too easy.
