Trying to understand timing map
Old Mar 4, 2010 | 01:12 PM
  #166
tscompusa2's Avatar
its safe enough for 1 pull to analyze.... go do the pull already!
Old Mar 4, 2010 | 01:15 PM
  #167
ethan169's Avatar
ok ok ok.. Ill do a pull with that detuned timing map set and the fuel map posted above. Im still at work but I will be leaving shortly and hopefully there wont be too much traffic. Ill report back soon.
Thanks guys. I think im more paranoid of breaking something so i guess im just trying to be careful...?
-Ethan
Old Mar 4, 2010 | 01:18 PM
  #168
tscompusa2's Avatar
remember to start at 2000rpm and go till redline, ...... and if you can, do it twice to confirm the first pull is legit.
Old Mar 4, 2010 | 01:30 PM
  #169
nonschlont's Avatar
after your pull I would clean up the 0 - 1000 / 100 - 260 range, as your timing is going up and down. make it sequential. You have 10 5 2 2 1 2 2 1
I would make it look like this:
10 8 6 5 4 3 2 1, (just an ex.) and also looking @ the same load cells going down the rpm axis isnt sequential either... You will most likely never hit those cells, but just for appearances sake...
I wouldnt worry bout it too much, the timing map seems ok, but wont actually know for sure till you post up a pull.
If you feel anything "odd" let off...
Old Mar 4, 2010 | 01:46 PM
  #170
tscompusa2's Avatar
heres my chart at just 18PSI wg pressure with my setup with 10.2 afr so far. logs say 2850 hz and 380 load.
i didn't think the black was this powerful at low boost? (i still need to get my LTFT mid dialed in, its +8.5 atm)
that is with 14* timing out the top.
Old Mar 4, 2010 | 01:49 PM
  #171
Mautofied.IS300's Avatar
Make sure you set the rpm cutoff (can't remember name right now), sometimes if you rev to 7400 or so, but have the rpm cutoff at 7600+, it will shoot up at the end like that.
-Will
Old Mar 4, 2010 | 01:59 PM
  #172
tscompusa2's Avatar
-Will
i reset the rpm to what i stopped at and it lowered the hp a bit, i smoothed it more also.
still tho..... i didnt think the power would climb like that with just 18psi.
Old Mar 4, 2010 | 03:11 PM
  #173
hediki12's Avatar
this isnt a stock turbo is it?
Old Mar 4, 2010 | 03:18 PM
  #174
tscompusa2's Avatar
that is a dumb question dont you think? LOL...... look at my signature man. its a fp black.
a stock evo 8/9 turbo at 18lbs wont crack even 310
Old Mar 4, 2010 | 03:28 PM
  #175
hediki12's Avatar
-_- your right im gonna say that im color blind so i dont look so stupid (im realy not) nice im curious why does the hp n tq dip so much on spool up? you have to reduce the timing that much ?
Old Mar 4, 2010 | 03:33 PM
  #176
tscompusa2's Avatar
its a really mild timing map right now, and i haven't even started to dial in the afr's, so im sure its pig rich during spoolup which hurts spool. keep in mind im not keeping it at 18lbs, i plan on running to whatever boost gives me 600HP+ evoM mode.
Old Mar 4, 2010 | 03:39 PM
  #177
tscompusa2's Avatar
not a big deal, my sig colors blend in with the background of the forum. this car is not tuned yet, its running 10.0~ afr's right now, and spoolup is overly rich, which kills the spool. i should be able to get it fully spooled by 3800 on the 2.3 i think. im still in the process of fighting my fuel trim MID right now. its at +8 now, hopefully the last scaling i did will set it straight, than i can begin the fun.
Old Mar 4, 2010 | 04:49 PM
  #178
Noize's Avatar
EvoM Administrator
Ethan, that recent map says Iveytune test at the top, and we are getting reported posts.
No vendor maps are allowed to be posted on the forums without permission. I removed the post, thanks.
Old Mar 4, 2010 | 04:52 PM
  #179
tscompusa2's Avatar
thanks for not closing the thread Noize. can you clean up my posts that say "delete"
Thanks.
Old Mar 4, 2010 | 04:55 PM
  #180
hediki12's Avatar
yea mines as well thnx
