GM IAT (MAT) all over the place.. 200.. -8 F
Old May 20, 2010 | 04:25 AM
  #181
Evoryder's Avatar
What issues are you still having or is it just the temp logging inconsistencies?
I can look at your rom> sk8tull at yahoo dot com
Old May 20, 2010 | 04:44 AM
  #182
Evoryder's Avatar
Now I'm thinking that you can't just change the scalings for the Sd Tables and MAT tables. You can probably get away with it on the Maf input but the Fuel temp input i don't believe so.
Old May 20, 2010 | 05:02 AM
  #183
And's Avatar
And
the car seems to be running ok, its just the inconsistancies of the MAT and IAT but I've been thinking as long as the car is using the IAT as the temp (as my temp sensor is connected to the MAF) then I don't have to worry what the MAT temperature is logging? (unless its used for something else)
As far as I'm aware I'm not using the fuel temp as an input.
Andy
Old May 20, 2010 | 05:35 AM
  #184
Evoryder's Avatar
You're not using fuel temp unless you physically wired it in to the ecu pin.
Now you're logging MAT correctly right? ...0x03 (SD Convert IAT to MAT)
Old May 20, 2010 | 06:20 AM
  #185
And's Avatar
And
yep using 0x03
Old May 20, 2010 | 06:45 AM
  #186
Evoryder's Avatar
I logged my air temps and the values look fine. No drastic fluctuations
Old Oct 15, 2010 | 04:04 PM
  #187
commodude81's Avatar
Quick question if I'm using Rom 88591517 do I have to add the mat patch because I do not see those options on the left side column
Old Oct 15, 2010 | 04:36 PM
  #188
Evoryder's Avatar
i believe you do.
Old Oct 15, 2010 | 05:08 PM
  #189
Ok, even if i wired the gm iat to the maf harness?
Old Oct 15, 2010 | 05:50 PM
  #190
Evoryder's Avatar
I don't believe u do. Only for fuel temp input usage.
Old Oct 15, 2010 | 06:31 PM
  #191
Ok great thanx, also when scaling the SD iat scaling do I scale the right side of it with the scale spoolinup has on his website? I use the celcius table right?
Old Oct 15, 2010 | 06:47 PM
  #192
Evoryder's Avatar
Yes celcius.
Old Apr 14, 2012 | 01:12 PM
  #193
wizzo 8's Avatar
GM IAT Scaling
To the op. What did you end up doing to fix your GM IAT reading? Mine reads 195F also in my 60F garage but driving around in 70F weather it reads 170. Obviusly my scaling is not correct. Does anyone have the correct scaling for it? Mrfreds patch is dead.
03whitegsr
Oct 8, 2017 08:16 AM
95630706
Oct 8, 2017 08:12 AM
Raceghost
Jun 10, 2016 11:28 PM
EvilEvolution8
May 11, 2016 04:50 AM
mksevo
Feb 25, 2008 11:16 AM
