GM IAT (MAT) all over the place.. 200.. -8 F
Old May 5, 2010 | 07:17 PM
  #91
Evoryder's Avatar
i posted my Desired ISCV initial step position with AC off-Neutral. That's what keeps it from dying.
warm up enrichment does nothing
Old May 5, 2010 | 07:22 PM
  #92
korndogg's Avatar
Oh, gotchya. Sorry, heh.
I just put those into my rom, I'll give it a try.
Thanks!
Old May 6, 2010 | 06:20 AM
  #93
Evoryder's Avatar
How'd it go
Old May 6, 2010 | 09:59 AM
  #94
korndogg's Avatar
Still wouldn't idle. It's really bad, I don't know if the IACV would be able to keep it running regardless of what I tell it to do.
Old May 8, 2010 | 03:03 PM
  #95
Evoryder's Avatar
Double post see below
Old May 8, 2010 | 03:04 PM
  #96
Evoryder's Avatar
I thinks me has the fix. Thanks to Appauld and Acamus
I'll let u know in the AM.
Post up your TempScaleFuel scaling
Old May 8, 2010 | 09:51 PM
  #97
korndogg's Avatar
That would be nice. However, I cannot find a table with that name. Could it have another name? I looked carefully through my entire ROM and couldn't find it.
On a side note, I took the evo to the 1/4 mile last night for kicks. I only got 2 passes in;
13.1@108 with 2.12 60' (lots of spinning)
12.7@109 with 1.84 60' (still spinning)
I don't have the tune where I want it yet, but I was pretty happy with that for where I'm at.
At cruise my AFR is 14.7 as it should be, but with just a little bit of throttle, 1-10psi of boost, my AFR goes retarded rich. But I think I know which SD tables to play with. I'm not logging my wideband yet though, and just moved into a new house today, so it might be a little bit on that one.
Anyway, that was a tangent. I can't find that TempScaleFuel table.
Old May 9, 2010 | 07:31 AM
  #98
Evoryder's Avatar
You looked in your V7 XML or the ecuflash Rom ? I guess I gotta be super specific with u lol
it's in your XMl under scalings...it may be correct just want to be sure
1/4 mile times are pretty stock like hehe ...what mods u got?
Tuning; lower the map VE for leaning out as well as the RPm. Higher number = more fuel in that given area. Top 2 Map VE cells are for WOT
Old May 9, 2010 | 10:18 AM
  #99
korndogg's Avatar
Oh, heh, yeah.. Sorry I'm such a noob at this. I found it.
Performance mods are basically just intake/filter, speed density, IC pipes, 3" exhaust, twin disc clutch, 255HP fuel pump.
I want to see 115mph out of this setup which should get me into the 11's. That's my goal because I ran 11.92@115 with my simple evo3 16g setup.
Thanks again for all of your help man, I really appreciate you keep coming back to help me. I owe you.
Old May 9, 2010 | 10:30 AM
  #100
Evoryder's Avatar
Did you install the MAT mrfred patch? The stuff in 941715 is wrong.
Also no luck on the start, my ca doesn't die. Just idles around 18-20a/f and the moment i drive off and stop in neutral its fine. !!!!!!!!!!!!
Old May 9, 2010 | 10:57 AM
  #101
korndogg's Avatar
I just compared mrfred's MAT patch to my TephraMOD-94171715-v7.xml file, and my XML matches mrfred's patch exactly.
I have to give the car quite a bit of gas; hold idle around 2k or so until my AFR richens up a bit. I can't just hold the gas in one spot either or it'll keep trying to die, I have to keep blipping the throttle.
Old May 9, 2010 | 11:17 AM
  #102
Evoryder's Avatar
You're still going through ecu flash ... Your XML is your Windows folder. Mrfreds scaling in the mat patch is for Celcius
Old May 9, 2010 | 04:21 PM
  #103
korndogg's Avatar
In my windows folder?
I saw mrfreds mat patch was using celcius, but I'm not sure which XML file you're suggesting I check out.. Can you give me the directory path?
Old May 9, 2010 | 06:56 PM
  #104
Evoryder's Avatar
My comp > program files > open ecu > rommetadata > Evo
For the MAT patch search the forum for mrfred mat logging
Old May 9, 2010 | 07:14 PM
  #105
korndogg's Avatar
That's where I was looking. My XML (TephraMOD-94171715-v7.xml) matches mrfred's MAT patch.
File is located here:
C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\ TephraMOD-94171715-v7.xml
