Fault Code Help Needed
Old Apr 6, 2010 | 01:04 PM
jamie_v1's Avatar
I have just completed a patch harness to allow me to run a E9 ecu in my E6 on sd the rom i am using is 88570008
I have 3 fault codes that have come up which i was expecting as i am not running mivec i just need some advice on how to disable them
P0000 ses code
P1021 Intake engine oil control circuit
P1012 I cant find a definite answer on this but i think it is intake cam position sensor
Thanks for any input
Old Apr 6, 2010 | 01:34 PM
RoadSpike's Avatar
According to my little cheater book.
P1012 VVT CAM
P1021 OCV Open Bank 1
So essentially the control valve to the oil port is open and probably is responsible for throwing the first code as well which is something to do with camshaft position .
Old Apr 6, 2010 | 02:08 PM
jamie_v1's Avatar
P1012 VVT CAM
Thanks for clearing the code what i relly need to know is how to disable these
Old Apr 6, 2010 | 02:42 PM
RoadSpike's Avatar
Disabling the mivec on an evo 9 is going to be really tough. I'm not really sure if i can answer those questions for you. Perhaps the ecu guru's like mrfred or tephra may know of a periphery setting that can accomplish it.
Old Apr 6, 2010 | 02:47 PM
jamie_v1's Avatar
I dont have mivec on the car its just the E9 ecu i have that is throwing the cel thats why i need to disable the cel's
Old Apr 6, 2010 | 05:15 PM
Boosted Tuning's Avatar
You should probably have a EVO 8 ECU in there, dont ya think?
Old Apr 6, 2010 | 05:20 PM
cossie1's Avatar
The problem is, he needs to run SD on his car (as I do on mine) however the SD patch for 90550001 (the Evo 7 sd patached rom) doesn't work correctly, and neither do the Evo 8 roms on our cars as they are the older Evo 6 models.
So Jamie has decided that the Evo 9 ecu has had more work done and more successful SD conversions therefore that is the Ecu he / we need to use to run SD without any issues.
I personally have tried 3 different 7 and 8 roms on my car, and all suffer with the same issue of spluttering around 2000 - 2500rpm on light throttle.
Old Apr 6, 2010 | 11:21 PM
jamie_v1's Avatar
As Russ has said we were having issues with the other sd roms we were using the E9 ecu has cured them i just need to get rid of these cel's and the swap will be a success
Old Apr 7, 2010 | 12:12 AM
Lucas English's Avatar
Thats just IPW drop out, there are a few ways to combat it. Are you using different ROMs only, or the ECU as well?
aaron
Old Apr 7, 2010 | 12:19 AM
RoadSpike's Avatar
aaron
using the 94170015 with speed density fixed it up for me
I'm thinking my year car just has some quirks it doesn't like with the origional v7 in the 9653 rom.
Old Apr 7, 2010 | 12:55 AM
jamie_v1's Avatar
aaron
Its not we have already crossed that option i have tried two different roms and two ecu's one from a E7 and one from a E8
The E9 ecu has cured it so i will be concentrating on sorting the cels rather than spending more time on the other roms and ecus
Old Apr 8, 2010 | 02:42 PM
jamie_v1's Avatar
Come on guys i need some help with this it has to be a world first and would benefit the community in the U.K
Old Apr 8, 2010 | 03:30 PM
RoadSpike's Avatar
Send a pm to MrFred, Tephra, and JC Banks so you can get some help. Those are the people that really know if what your asking can be done right now.
Old Apr 8, 2010 | 03:38 PM
jamie_v1's Avatar
Already have but there has been no help offered
Looks like i will have to sort this out myself
trinibt65
Jul 21, 2017 11:14 AM
Danial81
Lancer Troubleshooting
Sep 8, 2016 09:31 PM
napolean
Oct 8, 2015 05:02 PM
WickedWhtMR
Oct 23, 2007 09:55 AM
Redmondgold
10
Jun 24, 2006 11:10 AM
