SD help on evo 8
Old May 13, 2010, 12:22 PM
And
And's Avatar
SD help on evo 8
Hi All
I wonder if some one can help me, I'm trying to setup SD on the 260 rom (96530006 originally)? Although the 9652706 roms work fine with the car when I try and switch to the SD roms either the 9653706 and the 9651706 I get the following errors (below) each time I turn the ignition on, also I don't seem to get a temperature valve back. I have the MAP sensor wired into pin 73 and the MAT sensor plugged into the MAF connector (using the SpoolinUp harness). Any help would be appreciated.
I've attached the roms i'm using (on page 2 this post ), they all work and the car runs well with them all, if I clear the dtc's after the car is started with both the SD roms they don't come back, its only if i cycle the ignition.
Can anyone suggest what I need to do to get a temperature reading also?
Thanks
Andy
Diagnostic Codes:Oxygen Sensor
Intake temperature sensor
Throttle position sensor
ISC motor position sensor
Engine coolant temperature sensor
Crankshaft position sensor
Camshaft position sensor
Knock sensor
Injector circuit
Fuel pump relay
EGR sensor
Old May 13, 2010, 01:44 PM
JohnBradley's Avatar
I will have to noodle on this for a bit but I would think some of it can be the periphery settings. the rest of it has to be something not entirely compatible. I dont know enough about the EDM cars to know if you can try the 94170015? We can use the EDM, I would surmise you might be able to go backwards and use the US?
aaron
Old May 14, 2010, 12:11 AM
And
And's Avatar
thanks aaron, I've tried it so the bits are the same across the roms that work and the ones that through the errors but no joy. The car is a 260 which I think has the 96530006 rom in it as standard. The 94170715 roms are currently being fixed at the moment
Thanks
Andy
Old May 14, 2010, 09:54 AM
RoadSpike's Avatar
Thanks
Andy
Hey And.
Add this table to your rom xml
PHP Code:
<table name="SD Option: IAT Input for MAT - Use 0x03, Fuel Temp ADC_0E for MAT - Use 0x0E" category="Speed Density Programming" address="a821" type="1D" level="1" scaling="Hex8"/>
Since your using the the stock MAF input leave it at 0x03 instead of phenem's defined 0x0E.
Might be a similar thing for the MAP sensor but I don't know it off hand sorry
Old May 14, 2010, 11:00 AM
And
And's Avatar
hi I have that table and have it set to 03 now and the temperature works but i still get the dtc errors, any ideas?
Andy
Old May 14, 2010, 11:07 AM
And
And's Avatar
i also applied the SD patch to my 96532706 rom and the car does't have the errors anymore but now it is that rich the car won't start, every thing else is the same
Old May 14, 2010, 11:09 AM
RoadSpike's Avatar
Andy
Thats a pretty insane list of errors.
Did you play with the odbii completion patch? It should be defined in your xml already.
Old May 14, 2010, 11:10 AM
RoadSpike's Avatar
Double check your closed loop bit in FAA I believe.
I noticed a weirdness where the car would attempt a AFRMAP of 8 if the bit was set to full time open loop.
Old May 14, 2010, 11:13 AM
And
And's Avatar
no, just checked and the patch part 2 is set to ea60 so just changed it to eae5 and i'll go and try it.
mrfred
Oct 8, 2023 04:45 AM
mrfred
Jan 28, 2017 09:58 PM
SnailSpeed
Jan 1, 2017 06:52 AM
AlexEvo6
Jun 13, 2010 12:18 PM
Quick Reply: SD help on evo 8
