Tephra - e85 sensor question
Old May 14, 2010 | 01:42 PM
dyezak's Avatar
Tephra,
Would it be possible to drop the front 02 sensor, run open and closed loop off of the rear 02 sensor and use the front 02 sensor input for one of these: http://www.rmsautoparts.com/proddeta...?prod=12570260 (flex fuel sensor).
Then would it be possible to extrapolate between the Main Fuel Map (93 octaine) and the Alt Fuel Map (e85) based on the input from the flex fuel sensor?
Just thinking out loud.
Old May 14, 2010 | 01:49 PM
l2r99gst's Avatar
mrfred already has the flex fuel sensor project on his plate. I'm not sure how active he is or has been recently on it, but it's something that has been brought up in the past.
I don't think using the front O2 sensor input would be a good idea, though. Most likely an unused input or rear O2 (out of a choice of front/rear O2 sensor).
I would link you to the thread, but I don't have it handy...but I'm sure a search would find it rather quickly. It's either in this subforum or the alternative fuel subforum.
Edit: Here you go.
Old May 14, 2010 | 02:14 PM
scheides's Avatar
EvoM Moderator
All thsi stuff about deleting the front o2 can go away, no need for that. Just will need to use the ADC input that's already used for mapswitching. I think the hang-up here is developing a way to run an interpolated map based off of two existing other maps. It's not just an on/off switch like mapswitching, there's a LOT more involved.
Some day it would be cool to see this come to fruition, but for now, mapswitching is king!
Old May 15, 2010 | 03:32 PM
mrfred's Avatar
Originally Posted by l2r99gst
mrfred already has the flex fuel sensor project on his plate. I'm not sure how active he is or has been recently on it, but it's something that has been brought up in the past. ...[/URL]
I plan to pick this up again very soon, hopefully just after June 1.
Old Jun 16, 2010 | 03:48 PM
silex's Avatar
I have known about mrfred looking into this for some time now. Any update good sir?
Old Jun 16, 2010 | 04:39 PM
mrfred's Avatar
I'm moving my Evo to Portland this weekend. E85 is not as easy to get in Portland as it was in the Tri-Cities, so I'll be working on the patch very soon.
Old Jun 17, 2010 | 03:47 PM
silex's Avatar
Sucks to hear on the move
Old Jun 20, 2010 | 02:44 PM
mrboost05's Avatar
Edit: Here you go.
a good read rather old thread tho any updates been made since then ? i am sure it takes plenty of testing and trial and error.
tunermt
AEM EMS
16
Dec 13, 2025 01:11 AM
tephra
Aug 20, 2019 03:56 AM
Camaran
Feb 3, 2016 05:37 PM
RSMike
23
May 14, 2011 06:08 PM
JrCRXHF
Apr 4, 2007 11:37 AM
