TephraXMOD V1
Old Aug 3, 2010 | 06:08 PM
  #286
tephra's Avatar
I just checked.
I could store 90 different sets of maps in the current EvoX ECU.
Storing maps isn't the problem, switching between maps (and displaying what map your on) is the hard bit
Old Aug 3, 2010 | 06:15 PM
  #287
nj1266's Avatar
Hey Tephra, I do not know if it has been asked, but can you create two injector latency tables, one for 91 octane gas and one for e85?
Old Aug 3, 2010 | 06:18 PM
  #288
tephra's Avatar
The latencies should be the same.
Well actually the latencies that work for E85 will work for for 91/93
Thats the information I have anyways...
Old Aug 3, 2010 | 06:39 PM
  #289
nj1266's Avatar
Not always...It will be really helpful if we had two latency tables....Please, pretty please...I beg
Old Aug 3, 2010 | 07:26 PM
  #290
Golden's Avatar
My latencies are the same for E-85 and Pump.
Old Aug 3, 2010 | 07:28 PM
  #291
tephra's Avatar
yeah, i would like for some other people to chime in with their experiences before committing to anything
Old Aug 3, 2010 | 07:34 PM
  #292
Golden's Avatar
Probably need some tuners to tell us what they think. They tune 100 times more cars than we do.
Old Aug 3, 2010 | 11:35 PM
  #293
xPRimNT's Avatar
I just checked.
While 90 might be a tad excessive, I can see the benefit of 3 maps. Safemap(failsafe) and two switching maps. Whether it's a slight change to accommodate fuel differences or a full blown meth/E85 map.
Of course, I'm fine with my two, thank you very much
As for the latencies, if you've properly done MAF scaling and dialed in the injectors, switching to E85 *theoretically* should only need scaling changes, not latency. The injector latency isn't changing, just the amount of fuel you need is. Theoretically.
Old Aug 3, 2010 | 11:42 PM
  #294
tephra's Avatar
agreed.
generally what people have found in the past is that their 91/93oct latency doesn't work for E85.
But when they fix the latency and then go back to 91/93oct they find that the new latency actually works - albeit with a small scaling change...
Old Aug 4, 2010 | 08:29 AM
  #295
scheides's Avatar
EvoM Moderator
Injector latencies should stay the same based on E85 or Pump gas...you're right sometimes when going e85 you need to tweak them a teeny bit, but then going back to pump gas the new latencies work great; better than the old ones
I ran the same latencies on my FIC 1050's with pump gas, alky, E80, and E70 over about two years, they were all compatible with each other. I *guess* having separate tables might be nice but I'd probably never use it.
Old Aug 4, 2010 | 09:04 AM
  #296
fostytou's Avatar
EvoM Community Team
Originally Posted by GST Motorsports
You can switch that amount of maps on the Evo with the AP as well. The maps are stored on the AP unit itself, not the cars ECU.
- Bryan
They have a youtube video of it integrated on the fly with cruise control buttons. The digital boost gauge display selects one of 9 degrees of boost to show which map you are on.
Just speaking theory here: could we use dash control to temporarily put the tach at, for example, 1k RPM for map 1, 2k RPM for map 2, etc etc?
Old Aug 4, 2010 | 09:28 AM
  #297
GST Motorsports's Avatar
Ah I see now, pretty cool stuff:
http://www.youtube.com/watch?v=UtklJvN-Pds
- Bryan
Old Aug 4, 2010 | 02:31 PM
  #298
Kracka's Avatar
Sounds like the next gen AP is going to have NLTS too. Hopefully we get it first
Old Aug 4, 2010 | 03:21 PM
  #299
SiliconTek's Avatar
Sweet!
Old Aug 4, 2010 | 03:22 PM
  #300
murlo26's Avatar
I think Cobb is trying to avoid becoming a useless tuning tool as it did on the 8/9's but it won't matter.
ECUflash has way more support and is more or less free. I think Cobb is pretty low doing this as no doubt they are looking through stuff on Tephra's releases.
If they try to come out with speed density I would really really start to hate Cobb.
