Desired ISCV Not Working with Tephra 88590715
Old Sep 12, 2010 | 03:04 PM
rawkus's Avatar
I can't make any changes to these settings on either a Window's 7 or Window's XP machine. Any ideas? Thanks!
Dan
Old Sep 12, 2010 | 03:37 PM
rawkus's Avatar
Does not work with Mac and ECU Flash 1.38.2080 either... I am using the most current ECU Flash on the Window's versions.
I am having a very annoying idle dip after letting off throttle and want to fix. Please help!
Dan
Old Sep 12, 2010 | 10:01 PM
mrfred's Avatar
I wouldn't worry about it. Those definitions are wrong.
Old Sep 13, 2010 | 05:33 AM
rawkus's Avatar
Fair enough, but then what would be my plan of attack for fixing the off idle issue?
I have spent a fair amount of time trying to get the idle perfect on this car (both mechanically and with the tune) and this last part that bugs me is just completely ticking me off!
Thanks for the help.
Dan
Old Sep 14, 2010 | 06:39 AM
rawkus's Avatar
Any additional ideas? Does someone have the right definitions?
Dan
Old Sep 14, 2010 | 08:46 PM
Evoryder's Avatar
First set your biss correctly. Second try adjusting your Decel Fuel cut delay. Third log your timing vs rpm dip and add a little timing to help with the dip.
Old Sep 15, 2010 | 05:14 AM
rawkus's Avatar
Thanks for the advice, I have already adjusted BISS according to the service manual, but I will look into Decel Fuel Cut Delay and timing. I will report back with results. I will do some research, but any specific information of what I should be looking for with Decel Fuel Cut Delay?
Thanks!
Dan
Old Sep 15, 2010 | 05:34 AM
Evoryder's Avatar
Lower the numbers by 5-10% In your problem load areas
Old Sep 15, 2010 | 06:25 AM
rawkus's Avatar
I don't see Decel Fuel Cut Delay as an option on the rom. Am I missing something? I am using xml definitions from the Tephra v7 thread.
Dan
Old Sep 15, 2010 | 07:04 AM
D-VO's Avatar
Deleted
File Type: zip
RSGuy
Feb 11, 2021 04:42 PM
omniprobe
Jun 18, 2017 02:57 PM
Tadt
Sep 23, 2014 08:47 AM
Bitner16
Jan 20, 2013 03:37 PM
ralliartyz250
Nov 21, 2010 09:53 PM
