Dumb Question Knock issues in cold weather no increase in load
Old Dec 14, 2010 | 08:03 PM
Thoe99's Avatar
My suspicion on the bad gas was correct. Last week, I refilled my car with a tank from RaceTrac and retuned the car. Look at the difference:
Attached Thumbnails Dumb Question Knock issues in cold weather no increase in load-evoscandatalog_2010.12.14_22.27.01vscrapgas.jpg
Old Dec 14, 2010 | 08:10 PM
tscompusa2's Avatar
ya you gotta be careful where you fill up. ive experienced this with a customer from ny. i know its hard to keep getting it from the same source, but if all possible do so.
Old Dec 14, 2010 | 08:18 PM
Thoe99's Avatar
I used to use 7-11 for the past 5yrs, cuz it's right at the corner of my neighborhood, but this is the first time I've noticed such a drastic change in gas quality from them. I know they're not the best station to go to, but it's so convenient
Old Dec 14, 2010 | 08:45 PM
ZanarkO's Avatar
think my issue was similar changed gas from Shell/BP went to exon and now its fine. Also installed the bigger turbo kit and the car is running decently good. one question though. I bumped up my idle timing and idle but when I put the clutch in the car seems to like to almost stall abit. I think the issue is the huge intake going from a 3 inch to something that looks like a damn 5 inch on the inlet of the turbo. Any fix for this instead of going Speed density?
Old Dec 14, 2010 | 08:48 PM
Thoe99's Avatar
Are you still using the stock MAF?
Old Dec 16, 2010 | 10:24 AM
ZanarkO's Avatar
Yea still using stock maf. But I fixed it car idles perfect now and when I let off the clutch its like stock now. I just messed around with the idle maps and now its fine. But Man I posted in the engine/turbo tread but I can not figure this crap out. Im having major misfire issues now after swapping from multiple plugs and running as tight of a gap as .20. I have even gone as far as changing my coilpacks and buying new ones and spark plug wires and Im having the same issue. Anything past 15 psi is breaks up bad up top. I started with BR8ES's gapped at .24 I couldnt even get on it partial throttle at 15psi. Changed to BPR8es and ran .20 gap now Im good at 15psi but anything above that Pop pop pop.... The tune is fine I have taken out as much timing as I can and shes running on the rich side. Im stumped. Aren't the factory coilpacks good up to 400whp or slightly more? I just cant imagine needing individual coilpacks on just 20psi on a bone stock motor.
Old Dec 17, 2010 | 06:37 AM
burgers22's Avatar
Originally Posted by tscompusa
timing wont ever change with weather, just afr,
There are some temperature compensation tables for ignition in the tephra ROMs, just they usually go negative with temp.
Attached Thumbnails Dumb Question Knock issues in cold weather no increase in load-temp-trim.png
Live4Redline
Jul 17, 2024 07:09 AM
tenney
May 12, 2016 03:29 AM
Fireescape
Mar 26, 2016 05:19 PM
Kaveeth
Jan 26, 2015 05:35 PM
nemini
Sep 27, 2014 04:16 PM
