service engine light
Old Jan 8, 2011 | 08:24 AM
alexso15's Avatar
I have a service engine light that is on, i scanned it at autozone and it tells me that im not getting any signal from my cam sensor. I just changed my cam and crank sensors. I also had to disable the immobilizer for my car to start bc a few weeks ago my car stalled on me and wouldn't start. It turned out to be the immobilizer after $200 in sensors. But now the car drives and runs fine but except that annoying service light is on. Any advice on how to disable it through Ecuflash?
Old Jan 8, 2011 | 01:09 PM
vd's Avatar
vd
you don't need to disable CELs, what you need is to check with Evoscan and identify what error code is it. Then it will be easier to decide how to get rid of the CEL.
Old Jan 13, 2011 | 10:15 PM
alexso15's Avatar
service light
I got it scanned at autozone and it says that there is no signal to the crank and cam sensors. How is that possible when my car runs and drives? I did just replace both sensors. I even try to reset the ECU by unplugging the neg terminal of the battery anf reflashing back to stock rom. Will the car crank and run with the sensors swapped?
Old Jan 14, 2011 | 06:44 AM
ericpisanko's Avatar
Don't listen to Autozone ever again please.
I run the commercial section at an Autozone store....90% of the people in the company have never even changed their own brakes, yet alone know how to diagnostics your problem biased off a code.
Old Jan 14, 2011 | 09:49 AM
alexso15's Avatar
thats what i thought at 1st also. But i then scanned it with a friends scan tool as well and it pulls the same thing. But evoscan wont pull any DTC
Old Jan 16, 2011 | 10:45 AM
Im not saying their scanner is bad. Im saying their advice is horrible most of the time
Old Jan 16, 2011 | 10:58 AM
jvb6806's Avatar
what was the actual DTC that was thrown? which cam sensor did you swap or did you do both?
PO365 is for the intake cam position sensor
PO340 is for the exhaust cam position sensor
figure out which sensor isn't getting signal and diagnose from there. probably a bad connection after you swapped stuff out. or if you used an autozone sensor the odds are good that the new sensor you bought was bad out of the box.
if the issue was not originally the OEM sensors i would try putting those back in.
Old Jan 18, 2011 | 07:02 PM
alexso15's Avatar
looks like i accidentally swapped the sensors n the cel went away but then i drove around town and the cel came back on. ill do a DTC with evoscan tonight n see
Old Jan 19, 2011 | 06:55 PM
b16a2delsol's Avatar
I have the same problem, I keep erasing the code but it comes back. good luck
adron
Jun 16, 2020 10:34 AM
gray9evo
Midwest Region
Mar 13, 2016 09:13 AM
EVOMIZ
Nov 27, 2011 05:33 PM
hediki12
Aug 4, 2009 06:40 PM
Oettinger
Mar 9, 2008 06:29 AM
