EvoScan not reading diag codes
Old Jan 11, 2011 | 08:10 AM
Mitsu.kid.02's Avatar
Ok so i have a weird problem im not sure how to fix. I have the latest version of EvoScan, i can log the car with no problems all the time, but however when i try to read the DTC's it keeps saying "no response from vehicle ECU" every now and then it will work and display the codes, or if i have none at the time it will still read and connect but it will say "0 codes found" or whatever. Any ideas guys??
Old Jan 11, 2011 | 10:31 AM
92LaserRs's Avatar
Im getting the same thing. Running evoscan 2.8, 96531076 ROM, EVO VIII ECU. Had the same issue with the previous version as well. Cant clear DTC's all the time either, but actuator tests seem to function about 90% of the time.
Same discussion is going on over here:
https://www.evolutionm.net/forums/ec...e-support.html
Old Jan 11, 2011 | 11:24 AM
211Ratsbud's Avatar
somone said to try reinstalling evo scan and that worked for them.
ive never tried using the DTC reader, and the actuator requests dont work for me. "no response from ECU"
Old Jan 11, 2011 | 12:16 PM
92LaserRs's Avatar
Did the upgrade and a full reinstall, including removing all old files and and folders, and reg entries. Still no luck.
Old Jan 11, 2011 | 02:56 PM
Ill head over to that post, thanks man
Old Jan 11, 2011 | 05:27 PM
Boosted Tuning's Avatar
I have noticed that the DTC clearing/reading on EVOscan can be temperamental.
Usually the only way I get it to work is with laptop on, cables plugged in, open evoscan and then immediately try to read or erase DTC.
That method makes it work for me 90% of the time.
hearnoevo
Oct 14, 2016 09:15 PM
jeremysyty
May 13, 2012 03:43 PM
fireroasted
Dec 15, 2011 02:24 PM
DREVO978
Jul 20, 2011 09:03 PM
NoTec
Jun 18, 2007 10:56 AM
