disable the immobilizer
Old Jun 15, 2011 | 12:28 PM
galantman03's Avatar
so all I have to do to edit the bits is open it up in notepad, and change FAA bit 3 to 0 in between this <data>0</data> ? so now the immob is disabled correct?
Old Jun 15, 2011 | 12:50 PM
^ I just tried that and still cranks no start... am I missing anything? I have my stock injectors in there, but the map that I loaded to the evo ecu is for wrx injectors(high impedence) plug and play for our clips and ecu. Do you think thats the problem?
Old Jun 15, 2011 | 01:45 PM
todd6027's Avatar
send me the rom il disable the immo , what car is it ? long shot but does the fuel pump prime up if it doesnt swap pins ecu 8 and 22
Old Jun 15, 2011 | 02:24 PM
Ok I'll send it to you, via gmail. its a 03 mistu galant, but because I went turbo, my stock ecu doesn't understand boost, so I'm using an evo 8 ecu, made my own harness via pinouts. You want me to swap the a/c comp relay and the fuel pump relay, pins 8 and 22? Didn't think that the pinouts would change on evo 8 from different years. I'll give it a shot though
Old Jun 15, 2011 | 04:41 PM
So I tried the rom with the immob disabled, and I even swapped pins 8 and 22, still cranks no start. I'm begining to think I have a bad ecu... Question. do you have to save your edited maps on ecu flash before you flash them to the ecu? or can you edit them, flash them to the ecu, and then save them?
Old Jun 16, 2011 | 03:14 PM
todd6027's Avatar
you can edit then flash then save did the fuel pump prime ??
Old Jun 18, 2011 | 11:46 AM
no it didn't prime. so that still leads me to believe that I need to disable the imob with the ecu periphery. This is what tables I have in ecu flash since I added the periphery config. Now I don't understand how to edit the Faa bit3 from here, Did I load it right? or is there something else that I have to do?
Old Jun 18, 2011 | 02:13 PM
todd6027's Avatar
e-mail sent , can you send me the galant ecu pinout ??
Old Jun 18, 2011 | 02:16 PM
got the email, let me look it up real quick. this is what I used, it came of club3g, but plenty of galant owners that have done the swap used this no problems. where it says auto is my ecu and the aem is the evo ecu pinout
Old Jul 20, 2011 | 06:48 PM
So after all that work, it was still not starting. I tried to trace the immob, but forget that, it changes wires 2 times before going into a box. Hopefully it was just the harness I made, but I won't find out till January now
secretagentstv
Oct 5, 2014 12:13 PM
EVOMIZ
Nov 27, 2011 05:33 PM
indcent
Apr 14, 2011 08:17 PM
ballistic speed
Nov 23, 2009 09:06 AM
tscompusa2
Aug 27, 2009 07:56 PM
