how to turn sensors off?
Old Feb 10, 2011 | 05:39 PM
btmboards's Avatar
New to tuning myself since my tuner is no longer around.
I have a 06 IX MR and am instaling a plx wideband into the rear bung but need to turn the factory rear o2 sensor off to take it out. He had done it on my VIII i used to have but not real sure how. I have the tactrix 2.0 with ecu flash.
Old Feb 10, 2011 | 07:45 PM
Raptord's Avatar
Search a bit; it's fairly easily done. You'll need a patched rom though; I'd recommend Tephra v7 instead of just the rom patched for the rear o2.
Old Feb 10, 2011 | 09:29 PM
btmboards's Avatar
ya ready about it that looks like what we were using before, but i think i must really be missing something and may not be inteligent enough to make it into the threads. I can not figure out how to load it in
Old Feb 11, 2011 | 04:48 AM
Raptord's Avatar
I use Tephra v7 along with another patch to disable my rear o2.
https://www.evolutionm.net/forums/ec...hramod-v7.html
If you decide to switch to Tephra, you'll need to transfer your fuel, timing, boost and other relevant maps to the new Tephra rom. Use "Option 2 - Thanks to recompile 88590715 (v7 + Mods)" so that you have the patc to disable the rear o2 built-in.
I can check exactly how I have it done when I get home tonight if you'd like.
Old Feb 11, 2011 | 08:01 PM
btmboards's Avatar
where exactly do I paste the xml to, is the current issue im having.
I may be a newb with tunning but I am better with it than the computer software part so sorry for the having issues with the simple things
thanks for the help
Old Feb 12, 2011 | 08:36 AM
Raptord's Avatar
The extra xml data goes into "OpenECU\EcuFlash\rommetadata\mitsubishi\evo" then whatever romID you have. I'm using Tephra v7, so I edit "TephraMOD-88590715-v7.xml"
Old Feb 12, 2011 | 08:51 AM
rhaak76's Avatar
for god sakes if you dont know what you are doing at lease save a copy of your old rom.... just incase... i dint the firt time i hade to have english racing retun my car......
Old Feb 12, 2011 | 08:53 AM
rhaak76's Avatar
and i might need to lurn how to spell with the fat fingers......
Old Feb 12, 2011 | 09:18 AM
Raptord's Avatar
Good idea,
Also a good idea
Old Feb 13, 2011 | 10:35 AM
btmboards's Avatar
Ya I always save ever copy of everything I'm changing thanks a lot ill get into when I get home
My03evo
Jan 23, 2011 02:37 PM
dac001
May 16, 2008 06:37 AM
john2204
Apr 18, 2008 12:29 AM
StreetEvo
Feb 29, 2008 05:33 PM
fastassfourdoor
Jan 30, 2007 06:42 PM
