Can't start the engine with 96530006 replacement for 99270000
Old Apr 5, 2011 | 10:38 AM
Dochka's Avatar
Originally Posted by grayw
You are trying to use a rom ID normally used on a 4 plug ECU, there will be some issues. Try using 96260009 it's the JDM rom for use with the MR and dual solenoid setup.
Ok, i'll try that...
Btw i reinstalled the factory bcs and the ecu is still cutting the boost @ .6 bar...
Even if i re-flash the original 92700000 rom the boost cut is still there...
I also flashed the tephra v7 96530706 rom also without success
Why is the ecu doing that?
I've unmounted the Grimmspeed 3 port bcs and reinstalled the manual boost controller
Old Apr 7, 2011 | 04:42 PM
Dochka's Avatar
Problem solved!
I disconnected the ecu completely and reconnected it and voila problem solved everything works great
Pfff what a bad dream
But when i reflash the 96530006 rom back the problem appears again, even if i reflash the stock rom back, so i'll have to disconnect the ecu...
Old Apr 7, 2011 | 04:44 PM
grayw's Avatar
So are you using this ECU on a JDM VIII or earlier car?
Old Apr 8, 2011 | 05:24 AM
Dochka's Avatar
Originally Posted by evonut270
are you using a standard rom or tephra?
I have the two
SiC
Jan 19, 2016 08:03 AM
curamrdan
Apr 19, 2013 09:07 AM
gerard_fs
May 31, 2009 10:12 AM
Sin13
Jul 21, 2008 03:31 AM
