General non-information about factory ALS
Old Jun 18, 2012 | 06:04 PM
  #436
foxbat's Avatar
Air alone is not bad but not good enough for proper, psi producing effect. -ve timing use is a fuel collecting measure, it's not as effective when fuel is in CL mode.
We know that group_n subies had stock ecu antilag, but do we know of such fact about group_a/group_n Evos? If yes then a developer would only need to decipher the code similar to what Jason & prior guys did with the 16bit rom.
What did Jason think? He's a good candidate since he would know what it takes to get ALS working, software wise.
Old Jun 18, 2012 | 07:42 PM
  #437
211Ratsbud's Avatar
a few months ago he said it would be a while, but he said it was in his interest. we dont know of a group n type rom for the evo by any means from what I understand. except the evo 5/6 which used a 3 type hard case or something or other. I couldnt speak what the evo 3 had for sas/als function
Maybe at the very least he could offer the transition maps, which i still believe that a mechanical fix is the very next best thing. If timing comes down to just adding in an offset then what is the big deal? there could be one table.. timing adder which is already in existence by the presence of the IAT>timing table. I run full open loop anyways my self. The proper way would be to ignore CL while SAS active, and run CL once the SAS is done.
Old Jun 19, 2012 | 01:00 PM
  #438
Maikumaru's Avatar
group N rom is a good/great idea...but no clue if such a thing exists.
only way it will work with "stock Ecu" is if such a group N rom exists.
you can try mechanical fix, but trying to create as big as explosion possible in exhaust manifold is not the way to do it...you cant tune als adequately with stock ecu in current state. you can do the mechanical fix...but seems like that will do way more harm than good....
I have warped exhaust bits from using sas + -ve timing
I have yet to come across any Japanese or Uk person that is able to implement legit ALS on their car with stock ECU...
If you want ALS, aftermarket ECU is the only way. Im convinced of it now.
SAS helps turbo spool....does not "hold" boost
Old Jun 19, 2012 | 02:25 PM
  #439
211Ratsbud's Avatar
Ok, so with that in mind lets return to the what ecu can control air injection als question?
Ive been looking at vipec
And why was jb able to hold boost until the fuel timer expired?
Old Jun 19, 2012 | 02:40 PM
  #440
Maikumaru's Avatar
I believe any decent aftermarket ECU can control "pin 5" or the equivalent...just requires some code writing etc.
I was looking at AEM, but cant find any UK or JPN guys who use it, or at least use it with the secondary air system. I see lots of Motec, and UK guys like Vipec.
but at 1000+, little bit prohibitive to just pick one up to give it a whirl.
Not sure how much vipec costs, but could be a good alternative, along with autronic.
I think SAS could even be used to cool down turbo if programmed correctly with standalone
JB used the tired and true throttle kick...
I suppose if you used that and used it in conjuction with secondary air, who knows what would come out of that...would be good old fashion metal melting fun
Personally, I dont want to sacrifice my car to give that a whirl.
Old Jun 19, 2012 | 03:04 PM
  #441
foxbat's Avatar
I have tuned many motec equipped Evos before & I can assure you, it can't control sas, it simply doesn't have to, I never heard of any stand alone that do. Often, sas gets removed when cars are equipped with a stand alone.
What ECU/software did the Evo7 group-a (with offset sas) car use?
Evo 6 wrc/group-a used a metal cased evo3 ecu. Such ecu could contain the software logic needed for a sas aided ALS. A good plan could be to acquire such ecu & to send it to a developer to reverse engineer it & apply its ALS logic to various exiting evo roms.
Old Jun 19, 2012 | 03:10 PM
  #442
Maikumaru's Avatar
that is a very good idea. Just a matter of finding one...
Old Jun 19, 2012 | 03:33 PM
  #443
Maikumaru's Avatar
i dunno just seems like it is searching for fountain of youth, or atlantis, saskwatch or lost city of gold...
Old Jun 19, 2012 | 03:34 PM
  #444
foxbat's Avatar
http://www.lancerregister.com/showthread.php?t=96634
Old Jun 19, 2012 | 06:35 PM
  #445
211Ratsbud's Avatar
Jb used sas on Andrews car which i am speaking of. Both of them said als effect was limited by fuel timer in usdm rom. Just dont see what they do to even see positive pressure. Let alone 14..
Im not convinced its over yet. Getting closer to my sd dial in
Old Jun 22, 2012 | 09:57 AM
  #446
Maikumaru's Avatar
Nice find!!
Old Jun 22, 2012 | 12:47 PM
  #447
211Ratsbud's Avatar
Yes, but little to no information about the ecu and functions itself.
At this point im really curious to see how the rest of the airbypass ALS was implemented.
Old Jun 25, 2012 | 05:29 PM
  #448
211Ratsbud's Avatar
http://www.pi-innovo.com/products
hrmm..
its in some wrc cars.
Old Jul 6, 2012 | 07:54 AM
  #449
211Ratsbud's Avatar
http://www.generant.com/cv.shtml
Thinking that a valve like that on the charge piping leading to the outlet of an otherwise normal plumbed ewg except welded with 2 or 4 large runners leading to the exhaust mani and I'll have a very high flowing sas valve.
More air might mean less - timing.
Plus having a top and bottom port might be advantageous
Old Jul 7, 2012 | 06:18 PM
  #450
211Ratsbud's Avatar
Mechanical timing offset: can I just offset the cam sensor? Or do I need to adjust the reluctor on the crank too? I've been looking at the stock ecu fractional degree thread for a bit, plus a lot of stand alone ems forums. I'll end my quest when I find the answer is neither more -timing and more air
I think I can just do the cam sensor. people who adjust their exhaust cam end up with an offset correct? I just want to triple that or so haha
