General non-information about factory ALS
Old Nov 6, 2012 | 12:52 AM
  #556
foxbat's Avatar
Good progress! let's see the next step :]
Old Nov 6, 2012 | 02:14 PM
  #557
211Ratsbud's Avatar
Spent about an hour at the hydraulic shop . We agreed to knock the pipe work back to 1/2 because he didn't have 3:4 tooling. We can do 5/8 but we would need another set of jic x metric male fittings.
He asked me to come in a couple Saturdays from now to tinker.. And was quite intrigued by the concept .
2 weeks to proof of concept!
Old Dec 7, 2012 | 02:55 PM
  #558
211Ratsbud's Avatar
I haven't made it to the hydraulic shop yet . I'm working on an Arduino project aswell that will be switched with the sas pin. The concept is to use an in cabin potentiometer that adjusts the milesecond of spark delay vs rpm rounded to the nearest whole thousand rpm to yield a degrees retarded figure. Peak retard should ideally add up to -40 more degrees delayed ontop of the spark signal which is limited at -20 currently.
Old Dec 8, 2012 | 03:30 PM
  #559
211Ratsbud's Avatar
Cold side is beig plumbed tonight
Old Dec 8, 2012 | 05:35 PM
  #560
211Ratsbud's Avatar
Ok, so I plumbed the cold side and one thing I found is stainless steel braid is crazy sharp!
Ya know the flange I had cut for the exhaust manifold side with 2 holes overlapping? I still plan to use that for a stock exhaust manifold. However... i had one cut with 4 holes 1/2" so I can feed each individual runner with 1/2" from the valve. The plan is to eventually.. implement 4 ports vs two making it a 1-4 design instead of 1-2-4. Not a huge difference, but the holes that feed each runner are only 1/8" maximum on the stock set up.
Old Dec 9, 2012 | 04:01 PM
  #561
211Ratsbud's Avatar
Teaser
Old Dec 9, 2012 | 05:22 PM
  #562
211Ratsbud's Avatar
Code:
//*SAS
const int ALTMAP = 10; // pin which will be used to activate alt map
const int Toggle = 7; // defines pin for toggle switch to enable or disable
const int SolA = 3; // defines pin for solenoid a
const int SolB = 11; // defines pin for solenoid b
const int SASECUPIN = 2; // wire coming from ECU to SAS solenoid
void setup()
**pinMode(ALTMAP, OUTPUT); // sets pin 10 as output
**pinMode(Toggle, INPUT); // sets pin 7 as input, shuts off or turns on routine
**pinMode(SolA, OUTPUT); // Solenoid A output
**pinMode(SolB, OUTPUT); //Solenoid B output
**pinMode(SASECUPIN, INPUT); // reads pin 2 and will run entire code
void loop ()
this is my setup for the arduino code I plan to use as a micro ECU to establish positive control over the SAS valve. I will be using two solenoids on an Arduino Uno w/motorshield.
pseudo code runs like this
look for voltage at OEM SAS wire // will trigger the routine
trigger both solenoids to open valve // two ports on the SAS valve means positive open and closure
simultaneously apply voltage to alt maps ECU pin //achieves normal drivability until SAS pin says it wants negative timing
I want to work on a method that will close the program possibly quicker than the factory.. like a monitor on TPS ~V that will close the valves instantly to prevent backflow in the SAS pipework.
Attached Thumbnails General non-information about factory ALS-arduino-sas-helper.png
Old Dec 12, 2012 | 05:52 PM
  #563
211Ratsbud's Avatar
Originally Posted by 03whitegsr
I found a copy of the FSM and it had some interesting points about this sensor and how the ECU calculates airflow.
The sensor is a 0-5V output, not frequency unfortunately so whatever needs to be done for a Subaru sensor is the same that needs to be done for this sensor. Honestly though, the two sensors look very similar, they may even be the same sensor.
When used with the factory airbox
0.2 VDC = 0 g/s
1.8 VDC = 10 g/s
3.5 VDC = 119 g/s
4.9 VDC = 387 g/s
The MAF sensor has a built in thermistor which looks to have roughly the same scaling as the EVO VIII-IX IAT sensor in the stock MAF. This is just from memory though and I'd have to look at my notes to be sure. The X has two separate air temp sensors though and may deal with fuel enrichment very differently because of the two sensors.
The Baro sensor on the X is in the ECU. I also think it mimics the VIII-IX baro sensor on scaling but would have to look at my notes again. The X also has the 3-bar MAP sensor so there is likely additional mapping to accommodate MAP correction trims.
If an internal diameter measurement of the factory air inlet was taken near the airflow meter, we could probably calibrate it for other tube sizes pretty easily.
This is something that I would like to benefit from using a loggable maf pre-turbo to determine airflow after throttle plate has closed. I am on SD and will remain that way, but the information provided by this sensor could be very beneficial!
Old Dec 14, 2012 | 03:11 PM
  #564
211Ratsbud's Avatar
Buying an Evo x maf sensor new they're pretty cheap actually
Will be able to read baro adc on my sd rom
Old Dec 15, 2012 | 09:47 AM
  #565
211Ratsbud's Avatar
rewrote my arduino program to simply use power from teh SAS ECU pin to power the board and allow much less complicated code.
Simply put once the board gets power solenoid(s) open and voltage goes to alt map pin. This is adjustable in the stock ECU by controlling when the factory setup kicks in.
Old Dec 15, 2012 | 11:47 AM
  #566
211Ratsbud's Avatar
Code:
//*SAS
void setup()
**pinMode(10, OUTPUT); // sets pin 10 as output
**//Setup Channel A
**pinMode(12, OUTPUT); //Initiates Motor Channel A pin
**pinMode(9, OUTPUT); //Initiates Brake Channel A pin
**//Setup Channel B
**pinMode(13, OUTPUT); //Initiates Motor Channel B pin
**pinMode(8, OUTPUT);  //Initiates Brake Channel B pin
void loop ()
*//Solenoid A 100%
**digitalWrite(12, HIGH); //Establishes forward direction of Channel A
**digitalWrite(9, LOW);   //Disengage the Brake for Channel A
**analogWrite(3, 255);   //Spins the motor on Channel A at full speed
**//Solenoid 100%
**digitalWrite(13, LOW);  //Establishes backward direction of Channel B
**digitalWrite(8, LOW);   //Disengage the Brake for Channel B
**analogWrite(11, 255);    //Spins the motor on Channel B full speed
*analogWrite(10, 204); //applies 4v to alt map
I have to figure out how to make this happen when the SAS pin is active. I was going to use the barrel plug wired into the sas pin, but Im not sure how to know if it can handle that kind of load.
Old Dec 15, 2012 | 08:19 PM
  #567
211Ratsbud's Avatar
Jic 12 and 10 x m16 1.5 will be here Monday. The hydraulic shop deals with 5/8 the largest but I picked up the 3/4 just in case.
Monday and Tuesday I go out of town to secure a Brookfield power site but hopefully Wednesday or Thursday I can get this wrapped upppppp
Old Dec 20, 2012 | 03:04 PM
  #568
211Ratsbud's Avatar
Got these today 5/8 looks to be a proper size! 3/4 is massive
Old Dec 31, 2012 | 05:04 PM
  #569
211Ratsbud's Avatar
Been running a tia l38mm ewg as a blow off valve for a couple weeks now, 3psi spring seems to have no problems holding open on overrun. still no pipework made yet..
its hard to get places when you have an average construction job!
Old Jan 5, 2013 | 07:59 AM
  #570
211Ratsbud's Avatar
Going to make said pipe work now!
