problem with ecuflash..
Old Oct 2, 2011 | 07:13 PM
DREVO978's Avatar
Question problem with ecuflash..
ok.. so im having sum issues with my ecuflash.. the obd inspection and the phreriphry are acting crazy.. they where working.. now wen open them and on the column where you can change the numbers it says no matches.. y is that?.. i ahvent made no changes.. all ive done was try to install evuflash 1.29 and for the nlts+valet+knock patch i had to change it cause i did the one for the 1.30 and below and i have 1.42.. and now im having this issue.. any ideas.. i never seen this before..it wont even let me change the no match to numbers..
Old Oct 3, 2011 | 02:33 AM
DREVO978's Avatar
no one had this ever happen?
Old Oct 3, 2011 | 09:05 AM
MagicManRed's Avatar
are you using the same laptop to open your car's rom? maybe you don't have the XML tephra files loaded in your metadata folder in ecuflash in order to read those bits/information from the ECU??
I'm no ecu guru by any means... but that could definitely be the problem. Sound's like you're using another computer that doesn't have the files. I may be wrong. hope this helps.
-MR
Old Oct 3, 2011 | 09:33 AM
DREVO978's Avatar
Yea im using my personal laptop.. Everything has been working for a bit now.. I did all the patches and all wotked fine.. But wen I installed ecuflash 1.29 then deleted cause I relised I didnt need it to run the nlts patch.. Cause I could just use my
1.42..
Old Oct 3, 2011 | 09:35 AM
DREVO978's Avatar
Afta deleting the 1.29 things started acting up.. But one thing I noticed is wen I opened my rom on the 1.29 it was doin that..
Old Oct 3, 2011 | 10:03 AM
I think you should completely wipe all installations of both ecuflash's... reinstall the most recent, re-download the most recent XML's from Tephra... that will more than likely fix the problem. Be sure to completely delete any residual folders after uninstall of software. Reboot after every step/task/instruction/uninstallation/installation.
Old Oct 3, 2011 | 10:18 AM
DREVO978's Avatar
yea.. Ill try that today.. Hopefully it works.. Thanks.. Should I delete evoscan to.. Just incase then install again.. Or is that ok to leave?
Old Oct 3, 2011 | 10:19 AM
Naw, that's separate. You can leave EvoScan alone. (Unless it's an old version... would be nice to update) but one thing at a time.
Old Oct 3, 2011 | 10:37 AM
DREVO978's Avatar
Lol. Its the 2.8... But ur right one thing at a time lol.. Thanks.. Ill post up with results on how goes
Old Oct 3, 2011 | 12:04 PM
teribble's Avatar
A clean install will fix your problem. Sounds like when it was upgrading you got a glitch.
Old Oct 3, 2011 | 06:00 PM
DREVO978's Avatar
how do i go about deleting the ecuflash.. this damn thing wont let me.. it says uninstall for folder.. and wen i hit uninstall it does nothing.
Old Oct 3, 2011 | 06:37 PM
DREVO978's Avatar
i fixed it.. i just went to the evoscan site.. and uploaded the 1.42 version again.. and it fixed everything.. i think wen i installed the 1.29 while still having the 1.42 things got mixed.. but thanks for the help guys..
Old Oct 4, 2011 | 12:19 PM
SnailSpeed
Dec 13, 2015 04:31 PM
1fast97gsx
Dec 28, 2014 02:43 PM
robbyredneck
Jun 16, 2014 02:01 PM
Buguy
Apr 15, 2012 11:06 AM
Fast_Freddie
Sep 13, 2009 04:40 PM
