who would pay for a
Old Apr 8, 2013 | 10:00 AM
  #226
EyeDreamt's Avatar
Anyone have this and it still work? I have it now, but it cant seem to connect to op20... did a driver change?
Old Apr 10, 2013 | 02:23 AM
  #227
DanielAustria's Avatar
Would like to buy it too, tephra! Can you please contact me via PM how to pay and to get it, because you PM Box is full!
Old Apr 11, 2013 | 06:22 PM
  #228
lancer2008's Avatar
Tephra PM me with purchase offer
I would like to get on this a well. I need to swap a vin number on my edu. I had to get a new one.
Old Apr 16, 2013 | 09:33 PM
  #229
scheides's Avatar
EvoM Moderator
Sent you mulah, thank you sir!
Old Apr 20, 2013 | 12:27 PM
  #230
01CBR929's Avatar
The ayc/acd bleeder worked just as I was hoping! Thanks!
Old Apr 23, 2013 | 07:15 AM
  #231
FastAttack's Avatar
same
Old Jun 23, 2013 | 03:17 AM
  #232
evo_q8's Avatar
Hello! Need to confirm if this is working for all EVO X's or just USDM ones?
Let me know. If its all, then "my finger is on the (pay) button" lol! thanks!
Old Jul 27, 2013 | 01:14 PM
  #233
LGshow19's Avatar
Hey Tephra, I sent payment for these systems. Payment was sent from LGshow@yahoo.com.
Thanks!
Old Aug 3, 2013 | 08:31 AM
  #234
lancer2008's Avatar
tephra, since I cant send you a pm I got to ask you the question. Can you do the same thing and disable ASC permanently?
Old Aug 7, 2013 | 07:56 AM
  #235
xperience89's Avatar
Did it will work on my Ralliart 2009 for bleeding the ACD pump?
Old Sep 8, 2013 | 01:51 PM
  #236
Solarwater's Avatar
I tried emailing tephra a couple weeks ago, and got no reply.
I tried to read through and find it, but is the timing chain reset working?
Also, has anyone successfully bought a copy of the software lately ?
Thanks
Old Sep 18, 2013 | 10:58 AM
  #237
Clipse3GT's Avatar
Thanks
It works on older Ecuflash software and not updated Tactrix 2.0. Only desktop I run still 1.42 Ecuflash and have a non updated Tactrix 2.0.
The timing chain reset DOES NOT work. It has to be fixed in a new revision. But with the newest forms of software from Tactrix this program will not work. Tephra has to update it.
Old Sep 18, 2013 | 11:15 AM
  #238
LGshow19's Avatar
Yes I really would like an update.
Old Oct 15, 2013 | 05:50 AM
  #239
tephra's Avatar
hey guys,
im going to release a new version soon that addresses the recent ecuflash verson issues..
ive also added steering wheel angle, since a lot of people try to bleed with the wheel turned one full turn (usually because they have dropped the motor and flipped the wheel by accident)
timing chain RESET works just fine, but i'm working on the query..
on another topic I also have VIN re-writing working, but because of the security implications i only do it on an as-needed basis... I was tempted to put in FASTKey encoding as well, but i think the process is a bit complicated, ill see.. if I have time
edit - anyone thats paid will get the new version for free
Old Oct 15, 2013 | 05:54 AM
  #240
tephra's Avatar
just while im on the timing chain stuff.. i had a look at the code..
the changes for P0012 detection that mitsu did was just to double the limits.. at least thats what happened between 2009 and 2011 AUDM... bit dodgey
also as far as I can tell, these values aren't stored in NVRAM (ie where the VIN is stored).. this means whenever the ECU is disconnected the values are lost..
so i dont know how the ECU calculates chain stretch, ie is it computed over a long period of time (unlikely given you can disconnect the ECU to reset it) or is it calculated quickly over a short drive.
if the former, why when you change the ECU does mitsu say you need to save the learned values and then restore them onto the new ECU..
doesn't make sense...
