add or remove timing globally vs iat
Old Dec 13, 2011 | 07:03 PM
211Ratsbud's Avatar
Does everyone just zero this out? Is anyone taking advantage of this table? Currently im zeroed. Considering i did make good gains in the fall can i use this table to remove some timing when i bust my car out back into increasingly warmer weather? Id like to have accomplished a tune that is dully compensating.
Old Dec 13, 2011 | 07:36 PM
Raptord's Avatar
Here's my table:
Code:
-26    19    48    73    100    133    185    239
  0     0     0     0     -1     -1     -2     -3
Old Dec 14, 2011 | 11:57 AM
Dynotech Tuning's Avatar
This can be handy for MBC setups that generally over post a little in very cold weather as well as high IAT's in the peak of summer. How I set up the table depends on the IAT's when I tune the vehicle but it's generally the same as the one listed above except I would do -3@-26*F and -1@19*F.
-Jamie
Old Dec 15, 2011 | 06:40 AM
211Ratsbud's Avatar
-Jamie
Good thinkin lincoln. I wasnt sure if i would be able to get away with more timing at same boost level in low temp vs leaving mbc unadjusted and pulling timing. Is there a significant difference between the rationale in those thoughts?
Old Dec 15, 2011 | 06:49 AM
Spec-Ops1's Avatar
Code:
-2     -1     0     0     0     0      -1     -2
This is how I set up my cars in FL... It was 76 here yesterday...
Old Dec 15, 2011 | 08:21 AM
The basic principle is that the denser air will allow for more air volume to be ingested. This, combined with some MBC's boosting slightly higher in very cold weather can induce knock at times. In very hot climates, the air is less dense so you generally can expect slightly less air volume but the increased IAT's could present a problem for knock.
Ideally, you can just tune your car at one temperature and when the climate starts to change significantly, just adjust the global IAT table until no knock is present. Eventually, you can have a well defined table and no adjustments would need to be made year round.
-Jamie
Old Dec 15, 2011 | 09:30 AM
211Ratsbud's Avatar
Rodger that!
Old Dec 16, 2011 | 05:24 AM
stunt2's Avatar
what these numbers mean (-2;-1;0;0;-1;-3 etc.) when certain iat temp is reached, ignition is retarded by that number ?
Old Dec 16, 2011 | 06:51 AM
Raptord's Avatar
Yes, ignition timing will be adjusted by that value when at the corresponding IAT temp.
Old Dec 16, 2011 | 07:34 AM
211Ratsbud's Avatar
2 things:
This table interpolates to the nearest whole value or no?
Can the temp values be scalled so that I can reach those temperatures accordingly without causing problems to other tables? Although Im sure there is more than enouh range currently. Being that I am SD, i have yet to log the coolest temperature, and the hottest temperature, especially since my IAT sensor stuck at 80* for a while before I knew it.. time to start from scratch!
Old Dec 16, 2011 | 07:58 AM
It will globallly add or subtract timing as a whole number.
I am not certain if that temp table is shared.
-Jamie
Old Dec 16, 2011 | 12:31 PM
Raptord's Avatar
EcuFlash 1.43+ highlights table names that have been modified in the current session, so if you're using that you can try changing the scaling and seeing if it modifies the scaling in any other table. The only problem with this is that not every single table in the ROM is defined, so even if you get no change in what you can see, it could affect an undefined table we don't know about. But at least it's a start.
Old Dec 16, 2011 | 02:14 PM
211Ratsbud's Avatar
ok, im trying to adjust the min load required for this to take effect to be 200+. Why does it max out at 159?
TrendSetter
Mar 14, 2016 08:26 AM
Appauldd
Sep 21, 2015 08:39 AM
mrfred
Dec 21, 2014 10:13 AM
Kaveeth
Nov 8, 2014 05:25 AM
claudiumxg
Feb 26, 2010 03:24 AM
