Evoscan estimated WHP
Old Jan 6, 2012 | 04:32 PM
foxbat's Avatar
I wonder if that works at all? The 'estimated WHP' option under evoscan yielded logged numbers like 13.58417!!
Is there a formula to get actual WHP numbers out of that?
Old Jan 6, 2012 | 04:39 PM
AndyCT9W's Avatar
I haven't seen that function on evoscan, I'll check that out.
Try virtual dyno. It's free and pretty accurate. You just need a 3rd or 4th gear pull logged and open it in virtual dyno, enter the details of you'd car and brings up the dyno sheet. Shows hp/tq and can also show boost and afr.
Old Jan 6, 2012 | 09:00 PM
Raptord's Avatar
This. The calculations in Evoscan aren't accurate in current versions.
Old Jan 7, 2012 | 09:40 PM
JohnBradley's Avatar
I wrote that math A LONG TIME AGO in a galaxy far far....okay you get the picture. It is only accurate when its on pumpgas and the MAF is scaled like stock. I really dont suggest using it or worrying about it at this stage of the game.
Old Jan 7, 2012 | 09:56 PM
marcusE's Avatar
I have a question....
I was logging 410 whp constantly in Virtual Dyno on E85 when I lived in Michigan...
I moved to the middle of the country in Kansas and with e85 and the same boost I constantly only see 360 370 in VD..
What gives?
Pressure changing of different state effect it this much? lol
Old Jan 7, 2012 | 10:49 PM
AndyCT9W's Avatar
Air pressure, humidity, temperature. Quality of fuel is likely a factor too.
Old Jan 8, 2012 | 04:38 PM
foxbat's Avatar
A semi accurate whp measurement would be appreciated as an evoscan function in the future.
Old Jan 9, 2012 | 03:42 PM
evoscan's Avatar
Silver Sponsor
EvoScan v2.9 beta already has the new realtime power/torque feature... see the screenshots on the evoscan home page down the bottom..
2012evogsr
Jan 4, 2014 02:58 PM
JFuego777
May 31, 2010 10:58 AM
xmaciek82x
Sep 15, 2009 08:24 AM
fvaldes
Sep 22, 2008 10:44 PM
tatsuIX
Mar 8, 2008 08:23 PM
