Speed Density IAT options
Old Aug 5, 2013 | 06:08 AM
  #46
EvocentriK's Avatar
Ok I've seen a couple guys tap and mount in intake manifold now. Im just testing so I'm going to position it near the air filter to read close to what the MAF would read. I'm not really sold on SD so not making any changes that I can't reverse.
With the GM IAT scaling values - they are supposed to already be in celcius from spoolinup's site, but when I paste into the IAT table anything over 127*C (132*C to 150*C or the top 6 values in the table) is converted to 127*C when pasted in. The numbers cannot just be pasted in. What's going on there? tempscale and volts 16 are the scalings used.
Old Sep 6, 2013 | 09:30 AM
  #47
EvoPower81's Avatar
Need IAT settings for 90556701 ROM. Any help would be appreciated as i tried the settings from Jack or Trades but they seem not to work for my ROM
Old Sep 28, 2013 | 06:16 AM
  #48
catman78's Avatar
do these temps seem correct. Setting this up for 1st time.
Air temp is around 60, car is fully warmed up and idling
"Air Temperature" = 68
"MAF Air Temp Scaled" = 84.2
What are "normal" temp ranges?
thanks
Old Sep 30, 2013 | 08:43 AM
  #49
mrfred's Avatar
best way to compare is after letting the car sit overnight. turn the key to "on" and log with the motor not running. the reading from the gm sensor should be within 2 deg F of maf temp.
Old Sep 30, 2013 | 08:55 AM
  #50
catman78's Avatar
will test, thanks for response
Old Apr 24, 2014 | 06:57 AM
  #51
charlie.tunah's Avatar
Originally Posted by akeric
bump to confirm the proper scalings when using the fuel temp sensor (not splicing the GM IAT into the fuel temp ADC)....
Anyone else have this info? Or can anyone confirm or deny that the scalings in the available V7 SD roms are set for fuel temp or GM IAT?
Im just wanting to double check that what is in my rom is correct before going much further on my new base tune.
Old Apr 26, 2014 | 09:30 PM
  #52
211Ratsbud's Avatar
Best bet is like mrfred listed above, compare it to a dead cold car vs ambient air temp. That is how I detected a failed IAT which read a constant 34*. What really matters is that if it gets hotter your reading does that, and if it gets cooler the same. if you know where your readings lay, you can adjust the IAT corrections quickly. That is if you don't want to spend too much time fiddling with what not.
Old Apr 27, 2014 | 02:01 PM
  #53
Im seeing about a 10 deg swing in temp during my longest stretch of driving/logging. Never lower than 62.6F. Its probably 45f ambient.
Oct 8, 2017 08:12 AM
SnailSpeed
Jan 1, 2017 06:52 AM
EvilEvolution8
May 11, 2016 04:50 AM
03whitegsr
Sep 21, 2012 03:54 PM
Dynotech Tuning
Feb 13, 2012 09:19 PM
