NLTS help!
Old May 20, 2012 | 02:50 PM
evo8john's Avatar
NLTS help!
Hello! I am trying to set up NLTS and in the box for RPM drop there is no way to change anything. I have included a screen shot of what Im talking about. NLTS is enabled btw...
Old May 20, 2012 | 03:02 PM
AWDBus's Avatar
Can you try to open the box wider? Looks like you just have a different screen resolution then what is native for ECUFlash.
Old May 20, 2012 | 03:04 PM
evo8john's Avatar
Box wont open wider and I cant even select any options to manually enter a value. Thats why Im stumped...
Old May 21, 2012 | 03:01 AM
HyperDisorder's Avatar
Edit your Tephramod xml to make the NLTS description a lot shorter, then open EcuFlash back up and see if that fixes it.
Old May 21, 2012 | 11:29 AM
evo8john's Avatar
How would one do that?
Old May 21, 2012 | 12:51 PM
I assume that you're running Tephramod 96530709 so -
- Go to EcuFlash\rommetadata\mitsubishi\evo
- Edit the 96530709 xml in something like notepad
- Find the text that matches the description you showed in the image in your original post
- Delete/shorten replace the description and resave the file (only edit the description and not the whole line of code)
- Restart Ecuflash, open your rom and have a look at the NLTS RPM drop feature again
Old May 25, 2012 | 01:01 AM
evo8john's Avatar
Ok I tried to get that to work and still nothing. I dont think its a sizing issue since there are several other menus with longer descripitions that still show everything. Any of the gurus care to chime in? Really want this working for this weekend.
Old May 25, 2012 | 08:59 PM
wizzo 8's Avatar
Looks to me like the coding is wrong. I have added patches to my rom and have had this sort of thing happen to me. Found my mistake and fixed it. Problem fixed
Old May 26, 2012 | 05:52 PM
evo8john's Avatar
I havnt added any patches or anything but Im not sure if my tuner did or not. I really wouldnt even know where to look or how to fix it anyway lol.
Old May 31, 2012 | 10:21 PM
evo8john's Avatar
BUMPITY BUMP BUMP!!! Still need to get this going!
Old May 31, 2012 | 11:33 PM
Boosted Tuning's Avatar
The info for that table in thats ROMs xml is incorrect/has an error.
Old Jun 2, 2012 | 07:44 AM
evo8john's Avatar
And how would one fix this?
Old Jun 2, 2012 | 07:50 AM
MercenaryX2's Avatar
Delete the tephra XML's in the evo folder, then download and install the tephra mega pack on the v7 thread.
Old Jun 5, 2012 | 10:01 PM
awdordie's Avatar
like stated before the code is wrong in your xml for the rom your using. it should say some thing like row blah blah blah and column... the column part is what is messed up i bet. i had this happen where i accidentally deleted something in my xml where the column part was and it looked exactly like your problem.
Gordian79
Sep 14, 2016 02:20 AM
taylorgang
Apr 9, 2014 03:30 AM
BluEVOIX
Aug 28, 2012 02:17 PM
sharkm87
Oct 3, 2008 10:42 AM
