Idle Stability map?
Old Jun 5, 2013 | 06:19 AM
  #61
RS200Z's Avatar
Originally Posted by itzwolf
I have these maps listed for 2011 ROM's anyone have them for the 55570005/6? Rich?
This is what I came up with for the USDM 55570005/6.
Code:
<scaling name="Idle RPM Offset" units="RPM diff" toexpr="(32768-x)*1000/256" frexpr="32768-(x*256/1000)" format="%.0f" min="-200" max="200" inc="4" storagetype="uint16" endian="big"/>
<table name="Idle Timing Compensation 1.1" category="Idle" address="5F608" type="2D" swapxy="false" scaling="IgnitionCompensation">
  <table name="RPM" address="62900" type="Y Axis" elements="29" scaling="Idle RPM Offset"/>
</table>
<table name="Idle Timing Compensation 1.2" category="Idle" address="5F62A" type="2D" swapxy="false" scaling="IgnitionCompensation">
</table>
<table name="Idle Timing Compensation 2.1" category="Idle" address="5F64C" type="2D" swapxy="false" scaling="IgnitionCompensation">
</table>
<table name="Idle Timing Compensation 2.2" category="Idle" address="5F66E" type="2D" swapxy="false" scaling="IgnitionCompensation">
</table>
Old Jun 14, 2013 | 05:38 PM
  #62
masafina's Avatar
thanks
Old Jun 21, 2013 | 01:19 PM
  #63
JohnBradley's Avatar
The last map to idle control in the X is going to be something like airflow or load vs TPS. It will most likely be a 2D horizontal style table (doesnt really matter I suppose) with a minimum TPS value for a given load or airflow value.
Something like this (ignore current labels)-
Think of the purple side as airflow voltage or load, the bottom is minimum TPS duty for said voltage.
Old Jun 22, 2013 | 05:51 AM
  #64
RS200Z's Avatar
Would you be releasing the definitions for it soon?
Old Jun 22, 2013 | 02:51 PM
  #65
Well much like how this thread started I am just the Idea man, not the magic maker. I knew that idle stability maps would be in a DBW car much as I know there will be a minimum TPS vs airflow table. Subaru DBW teaches a lot in what to expect for generic controls.
If I had the def I would have shared, but alas I am not that smart of a disassembler.
Old Feb 16, 2014 | 01:44 PM
  #66
nonschlont's Avatar
any body found the addresses for the 56890013. damn addresses are different from the 10 rom..
TIA
TouringBubble
Oct 10, 2025 11:11 AM
r4p.t0x
Jan 22, 2025 10:03 AM
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Dynotech Tuning
Sep 20, 2016 01:30 PM
Appauldd
Sep 21, 2015 08:39 AM
