Idle Issues on Evo IX with AC on
Old Aug 23, 2015 | 04:00 PM
SmurfZilla's Avatar
AC kills the car. I'm sure this is nothing new. Would like to know some of my fellow Evo's owners settings and what field they changed in ECUFlash. I just swapped my IAC (Think it was bad because no matter what my tuner changed it would do the exact same thing even if he maxed out the setting). He set it back to a level he thought would work once I swapped it. I did and it made a bit of a difference but I would like to raise the table some.
I just dont know what table to alter and what to set it to. Any assistance would be awesome. Thanks.
Old Aug 25, 2015 | 07:09 AM
SmurfZilla's Avatar
Merlin's fix in another thread worked perfectly.
Now to fix the extreme lean condition on 1st gear starts
Old Aug 25, 2015 | 08:12 AM
kaj's Avatar
kaj
link for others that are searching this issue, please?
Old Aug 25, 2015 | 03:20 PM
SmurfZilla's Avatar
Forgot to post. Its Post 51 and 52. To be fair I ended up PM'ing Rich to help and he sent me the XML files since I could get them to display right (it was greyed out and not expandable like something was wrong with the XML tables I was trying to add).
https://www.evolutionm.net/forums/ec...h-decel-4.html
Old Sep 1, 2015 | 08:57 AM
mrfred's Avatar
its good that it works, but its a band-aid. real issue is somewhere else.
Old Sep 1, 2015 | 08:01 PM
SmurfZilla's Avatar
mrfred can you chime in on a thread i just created. I think the the root cause is the XML definitions on my tuners computers and in mine differ enough to cause tables to look different to him then what I'm seeing. And if I start a new base map and compare/copy his settings over to that map and send it to him there always seems to be some fields/tables that arent the same that he has to fix.
You ever seen this before?
https://www.evolutionm.net/forums/ec...-same-rom.html
project_skyline
Sep 13, 2012 11:50 AM
Redline06
13
Jul 12, 2009 07:56 AM
blackvr
Mar 22, 2009 03:15 AM
Toxin
15
Mar 14, 2009 12:47 PM
