Cranking ipw adder
Old Aug 29, 2017 | 02:47 AM
Racing boost's Avatar
Cranking ipw adder
Hi everyone
has anyone got the address for the cranking enrichment adder table 88570008 rom
I've fitted rc1000 injectors and now it's hard to start when warm
thanks mike
Old Aug 29, 2017 | 03:52 PM
merlin.oz's Avatar
430e
Old Aug 30, 2017 | 03:18 AM
88570008
Originally Posted by merlin.oz
430e
hi and thanks very much for your time as my rom xml is not defined for this table ,can I use the table from another rom I'd and swap the address thanks Mike
Old Aug 30, 2017 | 03:38 PM
Raceghost's Avatar
If you search on here for XML lists, you will find it.
I run an 8 ROM not a 9, so I don't have it readily available.
But you can find it.
Old Aug 31, 2017 | 11:05 AM
Hi thanks I've been looking for nearly 2 months now ,to
Add this table to my rom but still can't find it
Old Sep 2, 2017 | 09:45 AM
CDrinkH2O's Avatar
Look harder!
https://github.com/ripnet/evo/blob/m...ution%20MT.xml
Old Sep 3, 2017 | 08:24 AM
Thanks I have looked in all the rom xmls
I can see and it's still not listed anywhere
Cranking enrichment ipw adder
Thanks
Old Sep 4, 2017 | 11:59 AM
CDrinkH2O's Avatar
Thanks
1. Download the 88570008.xml file from the short cut I gave.
2. Save it to your ECUFlash xml file directory (usually C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo)
3. Open it in your favorite xml editor - Download and install Notepad++ if you don't have one.
4. Insert this code in the "fuel" section of the xml file and save your changes.
Code:
	<table name="Injector Cranking Enrichment IPW Adder (Main)" category="Main Map Fuel Settings" address="430e" type="2D" level="2" scaling="TimeInjCranking">
		<table name="Coolant Temperature" address="60d6" type="Y Axis" elements="9" scaling="Temp"/>
	</table>
5. Open your 88570008.bin ROM in ECUFlash and locate the "Injector Cranking Enrichment IPW Adder (Main)" table.
6. Change the values at your ambient temperature, up or down, in 5% increments until it starts first time every time!
Old Sep 4, 2017 | 12:52 PM
Thank you very much for your help
Thanks mike
knochgoon24
Jul 22, 2009 02:56 PM
Vivid Racing
28
Jul 8, 2009 10:31 AM
lan_evo_mr9
Apr 4, 2009 11:37 PM
