Knock sensor tune
Old Jan 1, 2026 | 03:34 PM
Mr EVOX's Avatar
Knock sensor tune
Hello,
I have knock at spool, what is a tune strategy for evo x?
Note: forged piston and rod, PTE 6466, ID2000
Thanks
Old Jan 1, 2026 | 04:52 PM
ViciousLSD's Avatar
did you try a new knock sensor?
Old Jan 1, 2026 | 06:16 PM
Jaraxle's Avatar
So need some information about your setup. Specifically, if it is a stock block or built (built are noisier than oem), and fuel type and turbo, etc...
I personally don't mess with the knock sensor settings unless it is warranted. E85 for instance will remain quiet while things COULD be going wrong, so you wouldn't make it MORE DEAF...
And if your stock block and stock turbo (or even say a 20g), then again; you wouldn't make it less sensitive unless your sure that the knock it is picking up is because of some other factor...
In short ... KNOCK KNOCK KNOCK..... is what happens BEFORE something breaks... By changing if the ECU can HEAR the knock, your taking away the opportunity for the ECU to pull timing and boost and safe the engine.
Old Jan 2, 2026 | 05:19 AM
Mr EVOX's Avatar
Stock block with 2.2 manley Stroker kit, PTE6466 with IDX2000, Fuel E85
I'm sure it is fake knock.
Old Jan 2, 2026 | 05:20 AM
Mr EVOX's Avatar
No, I have issue only at spool.
Old Jan 2, 2026 | 08:11 AM
ViciousLSD's Avatar
I had this BS "ghost knock" issue and the shop was chasing it with all their might since some people reported that the harness could be damaged when pulling/installing the engine (and the techs are morons). they "tested" the sensor and said it was fine. they even "tested" a new one but not installed on the block. they even installed haltech to cheat it. when I finally got it home I just reached under and lightly pulled the sensor wire and it came off. I changed the sensor, problem went away, and politely threw the haltech back to them
Old Jan 2, 2026 | 02:28 PM
Mr EVOX's Avatar
Yes, it is possible. But, I checked all harness everything good.
Old Jan 2, 2026 | 02:41 PM
Jaraxle's Avatar
Is lean spool on or off?
Have you pulled timing in the tables in advance is see if it STILL tries to pull timing?
What is the AFR during these spool knock events?
Is throttle WOT when it occurs, and does it occur at throttle % less than WOT?
Old Jan 2, 2026 | 03:04 PM
Mr EVOX's Avatar
Another issue: some time I have knock at cruse maybe my clutch making noise because twin clutch (tilton twin clutch).
Cruse: 1 to 7 degree
WOT:
Lean spool not available in my XDF: 58010005
Old Jan 6, 2026 | 06:33 PM
Jaraxle's Avatar
You should not be able to get knock at cruise. There is a table called Knock Sensitivity Load Threshold that basically says "if the load is less than this, ignore the knock sensor". I am curious what yours has in there!!!
Old Jan 7, 2026 | 02:52 AM
Mr EVOX's Avatar
Great, your answer helpful.
What about "Knock Background Noise Multiplier" and "Knock Background Noise Adder (SINGLE GAIN) #1" can you explain it?
evodrivesme
AEM EMS
Jul 2, 2009 05:49 AM
Nomad4g63
34
May 11, 2009 05:49 AM
stimpy
10
Sep 13, 2007 12:36 AM
crcain
38
Jul 15, 2007 09:26 AM
Noogles
Oct 5, 2006 12:21 PM
