Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Apr 27, 2015 | 05:46 PM
  #361
Klaiceps's Avatar
**UPDATE** I passed emissions and can confirm the settings shown below will work for Tephra ROM ID 88591715.
Originally Posted by randallsrt
I fail emissions today with an EVO9 on Speed Density 2.0 3D tune (88592715). I only had 3 monitors that were ready and all other came back as "unsupported"
I even plugged my scan tool into that evo9 that failed and also my personal evo 9 that is also on the 2.0 SD which verified that only 3 monitors were even available and set to pass.
Although the obd Force Passed tables are already implemented into that ROM/XML, no matter what options I choose, nothing changes on my Scan Tool.
I did experiment with another buddies NON 3D speed density patched rom (88590015) and that seems to be working perfectly fine after I patched the XML to display those tables. At this point I'm tempted to just make an emission only tune in order to pass, then switch back to the 3D Speed Density. Unless of course someone has any ideas...
Ok I think I found a solution to this. I can only be certain this works once I pass my emissions test which I plan on doing within the next few days.
So the problem is when I follow the instructions given in this thread, all monitors except misfire, fuel system, and components read not available. Everything I tried could not turn on the other monitors. I'm currently on Speed Density using Tephra ROM 88591715.
After further research, I stumbled upon this thread (MA Inspection FAIL - refer MAC) and decided to give Dynotech Tuning's suggestion a try (see post #11). The settings provided in his post are what a stock Evo ECU shows. I plugged in my scanner and it was able to pick up everything sans heated catalyst, secondary air system, and A/C refrigerant. However this time, catalyst, evaporative system, O2 sensor, O2 sensor heater, and EGR system came up as incomplete. I knew I was close.
So after a couple more tries, my screenshot below shows my final configuration which enabled all the pertinent monitors to read available. Even though the monitors tables in ECUflash all show 1s, everything except heated catalyst, secondary air system, and A/C refrigerant all show up as available.
Attached Thumbnails Patch: Force OBD Inspection Pass (acamus, mrfred)-obd-force-inspection.jpg   Patch: Force OBD Inspection Pass (acamus, mrfred)-screenshot_2015-04-27-18-55-13-1-.jpg
Old Apr 27, 2015 | 06:08 PM
  #362
kaj's Avatar
kaj
i'll have to check my setup.. but everything on mine was perfect, except i could not get the rear O2 to show a readiness code, so it wouldn't pass.
as of now, i'm still putting everything back to stock to smog
Old Apr 27, 2015 | 07:12 PM
  #363
3gturbo's Avatar
From what I'm seeing turning off certain tests from the periphery table actually turns off some of the obd readiness tests also.
Old Apr 27, 2015 | 07:54 PM
  #364
hearnoevo's Avatar
obd
Interesting, thanks for posting. Subscribed for your results.
Old Apr 28, 2015 | 04:35 PM
  #365
Klaiceps's Avatar
Just came back from emissions testing and I can confirm the settings above will work.
Attached Thumbnails Patch: Force OBD Inspection Pass (acamus, mrfred)-20150428_173624.jpg
Old Apr 28, 2015 | 05:38 PM
  #366
kaj's Avatar
kaj
Sweet. Ill try it out asap
Old Apr 28, 2015 | 05:45 PM
  #367
hearnoevo's Avatar
obd
Awesome, what mods did you have on your car at the time of inspection?
Old Apr 28, 2015 | 06:46 PM
  #368
Klaiceps's Avatar
FP Green Turbo
Cosworth 272 Cams
External dump downpipe
Catalytic converter
No rear O2 sensor. There's a wideband in place of it.
From what I saw, the inspectors didn't even look under the hood or under the car. All they did was plug in their scanner to check for codes and readiness monitors.
Old Apr 28, 2015 | 07:28 PM
  #369
kaj's Avatar
kaj
FP Green Turbo
Cosworth 272 Cams
Catalytic converter
Lucky. BAR has our smog shops so scared out of their wits, they are failing people for legal mods, just in case. They are coming down haaaard on our guys. Makes me want to open up a smog shop.
Old Apr 28, 2015 | 08:07 PM
  #370
Klaiceps's Avatar
Yeah you guys in California have it really rough. I don't know how guys who have modded Evos (or any modded car for that matter) as daily drivers do it. Here in Colorado, if your car is 7 years old or newer you don't need to do a sniff test. They'll only check for codes and OBD readiness. If older than 7, then a sniff test is needed. I also have a K20 Civic that passed emissions last year with only a high flow cat for emissions purposes. Everything else needed for emissions has been removed.
Old Apr 29, 2015 | 08:20 AM
  #371
kaj's Avatar
kaj
It sucks. We now have no sniffer on newer cars- just the OBD check, but it's the visual that gets everyone. If you repaired a vacuum line with colored silicone? Fail. Had to run a new wire to your fuel pump? Fail. I saw both of those happen in the past 60 days. No exaggeration.
Old May 14, 2015 | 11:08 AM
  #372
fletchmasta's Avatar
Hey the link to the video isn't working. Does anyone have that video?
Old May 14, 2015 | 11:55 AM
  #373
Also can this be done with AccessTuner Race and an AP?
Old May 17, 2015 | 04:22 PM
  #374
Bump:
Anyone?
Old May 17, 2015 | 05:02 PM
  #375
kaj's Avatar
kaj
Originally Posted by fletchmasta
Bump:
Anyone?
someone correct me if i'm wrong, but i think not. from what i've seen with AP, it's pretty limited compared to ECUFlash.
the methods in this thread are only avail because people have picked apart the ECU to find these options. since ECUFlash is open to all, it's shared as such.
AP is completely separate.
