Adding load columns and RPM rows to maps
Old Oct 1, 2009 | 10:59 PM
  #76
Evo_Jay's Avatar
Originally Posted by Jack_of_Trades
I think this resolution would be my ideal layout so 99% of users wouldn't ever need more resolution, IMO. I know Mellon is one of the highest stock MAF loaded cars right now and he's just at 500 now and like was mentioned, the built engines offered these days can reach 10K RPM. I know this is bigger than will probably be the final product, just wanted to throw it out there
LOL, good thing I got rid of my netbook. We gonna need bigger screens on our laptops now.
  #77
diiirk@AwdMotorsports's Avatar
Originally Posted by jack_of_trades
i think this resolution would be my ideal layout so 99% of users wouldn't ever need more resolution, imo. I know mellon is one of the highest stock maf loaded cars right now and he's just at 500 now and like was mentioned, the built engines offered these days can reach 10k rpm. I know this is bigger than will probably be the final product, just wanted to throw it out there
give me that!
Old Oct 1, 2009 | 11:26 PM
  #78
GST Motorsports's Avatar
Originally Posted by tephra
d) Can someone help me transpose the original maps into the new size? This will require copy/paste and then using ECUFlash's 'Interpolate 2d' to do each little bit...
Here you go.
Old Oct 1, 2009 | 11:27 PM
  #79
Fast_Freddie's Avatar
Veteran: Navy
The RPM & Load scaling on this also shouldn't effect the low coolant temp timing trims either since it is still using the stock RPM axis down low...
Old Oct 1, 2009 | 11:56 PM
  #80
tephra's Avatar
^ lol - that car is going to run like a ****, 9* @ 10500rpm and 500load... :P
OK I am ready for a tester.
If one of my usual 96530006 guys emails me I can send them a test ROM + XML
We can finalise the rpm/load points when everyone has time to think about it.
^Thanks Bryan - I havn't included it yet, but we will try and get all the maps filled out for the final version!
Old Oct 2, 2009 | 03:45 AM
  #81
MR Turco's Avatar
OMG!!!
I just jizzed in my pants.
I actually PREFER that the fuel and timing were using he same axis points since I want to tune THAT particular timing/load point to THAT specific fuel amount. God, this will be so sweet. I bet we can really get a lot more out of our tunes with this....keeping the knock monsters at bay.
Same here, would prefer they were the same size as well. It is annoying not having consistent resolution.
Great work Tephra!!!
Old Oct 2, 2009 | 04:46 AM
  #82
Jack_of_Trades's Avatar
That was my intent I planned ahead
lol, I obviously just copied the last column/row and extended it so it reacted the exact same way it would if somoene exceeded the stock maps limits. It was more to show the axis' anyhow
Old Oct 2, 2009 | 04:53 AM
  #83
Veteran: Navy
Yeah I tried messing with the low coolant temp timing to match a rescaled map the other day and the car behaved poorly...
Old Oct 2, 2009 | 04:57 AM
  #84
hediki12's Avatar
omg you guys are the best!!! im gonna be running some sick times come spring!
Old Oct 2, 2009 | 06:22 AM
  #85
denver's Avatar
Jack those scalings look prefect! That should pretty much take care of 99% of the people out there!
This is VERY exciting!
Old Oct 2, 2009 | 07:02 AM
  #86
03whitegsr's Avatar
I don't know how possible it is, but if the axis used for the fuel are only called once, could you use those axis on the timing as well? Thus anything that used the timing axis originally will go unchanged and the fuel and timing axis will be locked together.
I know the fuel and timing use different values for loads, so maybe this isn't possible?
My concern about changing the timing axis is that what would happen when you get beyond the stock table area? For example, the stock low coolant timing map wouldn't have enough data to cover all the additional sites, would you end up pulling the wrong values out of the next adjacent map in the ROM?
Awesome work though and I hope the testing goes well. I'm not one of the guys that needs 500 for load, but I would love to not kill low end resolution just to get to 360 or so load.
Old Oct 2, 2009 | 07:48 AM
  #87
denver's Avatar
Im pretty sure tephra already addressed this, and that the plan is to have the fuel and timing axis the same, also they will have the same table resolution.
Yeah I am def going to keep the axis the same.
ie if you change the fuel rpm axis the ignition rpm axis will automatically change too
makes things a tiny bit more simple on my end as well.
btw i'm doing 96530706 first - so if someone wants to be a brave guinea pig let me know
Old Oct 2, 2009 | 07:50 AM
  #88
laramie_05MR's Avatar
10K rpm and 500 load with stock like resolution would be amazing
Old Oct 2, 2009 | 07:53 AM
  #89
denver's Avatar
+ 10000000000
Im so excited about this, I cant wait! There are several places last time I was out tuning I was wishing I had more resolution!!! With this, those areas can be perfect now!!!
Tephra is an ECU code writing GOD!!!
(currently checking my $$$ flow, for donations!)
Old Oct 2, 2009 | 09:29 AM
  #90
JohnBradley's Avatar
Here is the scaling for a 4 bar out to the edge of Kpa for us SD guys
Dont stare at the timing numbers too hard, nor my rpm scaling, as I will be changing it for the 2.2 I am sure
