New EcuFlash 1.44 problems
Originally posted by 92LaserRs
My Mut table looks fine, and 3d works for me. Im not sure what the problem is with it on notebooks though. I always just have to drag the table over to view it. But it displays and pivots properly.
How do you choose Load or PSI based boost control for v7-88590715? I'm planning on running the stock BCS for the next few weeks and just want to leave it as is. I'm confused because both Load and PSI based boost control tables are in the same rom. Thanks
NVM, found it under global boost control 'type'
If you over wrote your existing install it will be in one of the "backup001" etc folders.
also what are the benefits of upgrading to this??? whats the + ???
http://evoecu.logic.net/wiki/Add_MUT_Table_To_EcuFlash
Someone can correct me if I am wrong but wouldn't setting your mut tables with the second xml code on this page correctly show the 3d tables on notebooks? If you are using the tables with all the f's in it that would be causing the issue correct?
Im having a slightly different issue with mine.
Every time I attempt to edit an XML file (using Notepad ++ Portable) then save it an error pops up saying "Please check whether if this file is this file is opened in another program".
any ideas?
any ideas?
I had nothing but trouble trying to use a XML editor to change XML code in ecuflash. I just change the code using a basic text editor (regular notepad) then save it to your desk top as a .XML file. Then drag that file into ecuflash folder containing the XML you changed. Then Windows asks if you want to replace the file with the new one, click yes, and you're done. Works for me everytime.
