Pump Dyno: GT35R/stroker 414/370 Comments?
I think your numbers are in the ballpark. Maybe just a little low right now but I think your tuner is smart to take his time.
I made 474whp with 93 oct @ 20psi at AMS before adding the twin fuel rail set up. I'm getting the new numbers in the next week or so but Martin is doing the same thing on the tune taking it slow.....Dyno then street tune....then back on the dnyo etc.
Wait till you get your numbers on pump/meth and C-16 sttings. You will be very happy I'm sure.
Good luck
Good luck
I'm running a 3" upper IC pipe now and 2.5" lower IC piping. Debated on the intake mani/TB and decided it wasn't worth the cash right now. Maybe next year. I'll never be done! Next up is probably a better fuel solution of some sort, front LSD, rear axles... I want to max the 35R and keep the spool low. I'm a long way from maxing the 35R. I think I'll just keep throwing fuel and boost at it when I itch for more power.
I also have a strict "no sticker" policy, so with no wing, stock rims/stock O3 style it should be a nice sleeper...if an Evo can sleep ha ha.
Which is bad cause that leaves ya with 1800 rpm to play with
My Brian Crower pro rods were machined wrong and the machine shop didnt catch it. The rods burned into the crank and took the bearings out. I have a copy of your machine shop bill and the machine shop had to rebuild the Brian Crower kit just to make it work ...sad in my option for a kit that cost $3000So im back to the stock crank and Oliver rods and Ams Ross pistons
Time to rev high for me.
This is a street car. I was already scared of the lag of a bigger turbo. I was proud of myself that I sacked up to a 35R at all when I was tempted to go stock or 50trim. So .63 made sense. When I max it out I'll consider going bigger. That'll probably take me a while. By the way here's the latest smoothed out dynosheet...
eddie, who tuned your car? and like 35revo said, what else do you have done?
My 2.3 35r is finally broken in and im just waiting on RNR to send a few small parts my way (they need to hurry up) for it to be tuned...
Yeah my 2.3L has 555WHp with my 35R 30lbs of boost, HKS 272 Cams on 93 and alcohol. I Think I hit 564 on the dyno but settled with 555, this was almost 2 years ago. I have alot of other mods aswell, listed on my garage. You should be about there with Alcohol/Meth. I'm going for 800 now bigger turbo. The 35R just isn't enough.
kylefowlie
Jul 5, 2014 06:14 PM
BoostLover99
Sep 8, 2010 03:49 PM
Tracy
21
Nov 18, 2005 05:20 AM
