FP RED dyno results thread
ok so i got another little off topic question to all the fp red people. So how are you guy running you oil lines, are you useing the stock way or did you use a differnt place to get more oil because on their web site they reccomend that you use a differnt place that stock????
Here is my result, but its just short term pending the double pumper and bigger injectors being installed in the next several days...
501/403 at 25psi
https://www.evolutionm.net/forums/ev...ates-come.html
501/403 at 25psi
Mexican evo with FPRED 509 WHP!!!
Hi my name is Ricardo Gonzalez i from chihuahua mexico my car is evo 9 mr with few modification:
FPRed Turbo
Turbo Manifold Megan Racing
Nvidia 02 Housing
INJEN LANCER EVO INTAKE LOWER UPPER INTERCOOLER PIPES
ETS big Intercooler
Ecu aem
5 bar aem
iridium ngk
Full 3" CatBack hks
3" TestPipe hks
3" Down Pipe hks
Kelford 272/272 Cams
GSC Valve Springs
ARP Head Stud Kit
Walbro Fuel Pump
pti 1000cc
Hallman Evolution RX MBC
double Gauge Pod
Autometer 30 Psi Boost Gauge
AEM Wide Band
ACT 6 pucks Clutch
Groupe-S Flywheel
Groupe-S Steel Clutch Line
tune by richard walker speedfactory paso texas
the results is 509 whp the video is here!!
http://www.youtube.com/watch?v=u1Kk0...e=channel_page
FPRed Turbo
Nvidia 02 Housing
ETS big Intercooler
Ecu aem
5 bar aem
iridium ngk
Full 3" CatBack hks
3" TestPipe hks
3" Down Pipe hks
GSC Valve Springs
ARP Head Stud Kit
Walbro Fuel Pump
pti 1000cc
double Gauge Pod
AEM Wide Band
ACT 6 pucks Clutch
Groupe-S Flywheel
try here i belive it is where i stated your question https://www.evolutionm.net/forums/en...ml#post6806870
Here is my fp-red results on 91 octane 455whp/410wtq on a dj
This dyno chart is comparing a fp-red to a fp-grn.....same mods, other than cam timing differences & turbo's.
my mods: fp-red, weapon-r intake mani, mil.spec 65mm tb, ported hotside, exh mani, licp, full 3"dp, turbo xs fmic, pte 1200cc inj, cosi m2's @ +2int/0exh, aem ecu, tuned by me.
dyno charts:
dont laugh to hard
on my pathetic power curves.....i dont understand the dip at 6k between the 2 runs....maybe it has something to do with my intake mani was cracked on all 4 runners & 2 of the funnels were bouncing around in the plenum...YOU GET WHAT YOU PAY FOR
there isnt any knock within the data logs & afrs are @ 11.0...your head doesnt hit the steeering wheel when you run through this rpm either???The power dip is crazy...i dont understand... i didnt get this dip with the ported oem mani....
i ran 28psi on the red, 26 psi on the green...the engine responds to the higher boost on the red. on the grn, it didnt make anymore power @ 28 psi vs 26psi...
dyno charts:
dont laugh to hard
