FP RED dyno results thread
Old Apr 20, 2009 | 07:20 PM
  #211
kaansahbaz's Avatar
nice
Old Apr 21, 2009 | 07:09 PM
  #212
04AWDTURBOEVO's Avatar
Originally Posted by Aby@MIL.SPEC
Here is my fp-red results on 91 octane 455whp/410wtq on a dj
This dyno chart is comparing a fp-red to a fp-grn.....same mods, other than cam timing differences & turbo's.
my mods: fp-red, weapon-r intake mani, mil.spec 65mm tb, ported hotside, exh mani, licp, full 3"dp, turbo xs fmic, pte 1200cc inj, cosi m2's @ +2int/0exh, aem ecu, tuned by me.
dyno charts:
dont laugh to hard on my pathetic power curves.....i dont understand the dip at 6k between the 2 runs....maybe it has something to do with my intake mani was cracked on all 4 runners & 2 of the funnels were bouncing around in the plenum...YOU GET WHAT YOU PAY FOR
there isnt any knock within the data logs & afrs are @ 11.0...your head doesnt hit the steeering wheel when you run through this rpm either???The power dip is crazy...i dont understand... i didnt get this dip with the ported oem mani....
i ran 28psi on the red, 26 psi on the green...the engine responds to the higher boost on the red. on the grn, it didnt make anymore power @ 28 psi vs 26psi...
Nice numbers on 91, Aby.
We have been following each other's progress for a while. Just like me, you have moved from the Green to the Red.
Good to see the results are similar. Can't go wrong with either of the FP Turbos.
Green is fun, Red is wild .
I am making some new changes to my set-up, but will be still using the Red. Hope to make a little more HP.
It would be nice if FP can put the new cover on my Red. They got it up there for minor work right now.
I will post updated results when everything is ready in my car.
Have lots of fun with yours .
Old Apr 21, 2009 | 07:42 PM
  #213
bambooi's Avatar
Was there a big difference from green to red? Do you guys wished you would have gone to a bigger turbo?
Old Apr 22, 2009 | 10:17 PM
  #214
Just bolting the [Red] on = (90~100)+ whp from a Green with supporting mods and a good tune, and that is very significant.
You can go bigger, but on the stock ECU, stock E. Manifold, D.Pipe, ()2 Housing, etc., you can't beat it.
Old Apr 24, 2009 | 06:56 PM
  #215
JohnBradley's Avatar
522/412 at 31psi on E85 today on one of our customer cars. Going to go back to the dyno next week for a little more boost.
Mods that matter:
9:1 JE/Eagle motor
Stock head
Cossie M3
ETS 4.5" Intercooler
ETS Magnus specific UICP
ETS mini battery kit
Magnus Cast intake
1200s
Twin 255s
Mil.Spec 65mm TB
Dynosheet to follow soon
Old Apr 25, 2009 | 05:26 PM
  #216
SoCal Rally's Avatar
<snip>
Aby, 28psi on crappy CA 91 pump with no knock?
Old Apr 26, 2009 | 12:52 PM
  #217
mchristian's Avatar
Originally Posted by MR. EVO MR
got my 8 mr tuned yesterday, with all supporting mods.
391whp
353tq
26.5 psi
93 pump
they should also call it the fun turbo
Really? This is only 40whp & 3wtq than my stock 9 turbo at 24 psi, tuned by Sean Ivey. Any other mods besides the red?
Old Apr 27, 2009 | 03:49 PM
  #218
Aby@MIL.SPEC's Avatar
no... i'm not running much timing either @ 28psi
4k=5.8°
5k=5.8°
6k=6.9°
7k=7.3°
8k=9.0°
these values are for 20c inlet temps.
The ignition map is offeset based on inlet temps & retard to -4.92 @ 50c.
my engine is sensitive @ 6,900 & 7,400rpm
Old Apr 28, 2009 | 08:05 PM
  #219
detroit pistins's Avatar
nice thread.
Old Apr 29, 2009 | 04:57 PM
  #220
Daryl Nilsen's Avatar
I will be installing my red and kelfords this weekend and have scheduled a tunning session by Buschur for tuesday, il post my results tuesday night.
Old Apr 30, 2009 | 07:02 PM
  #221
stryfetew's Avatar
Anyone got any results yet on the new red with the 80mm compressor housing?
Old May 1, 2009 | 08:35 AM
  #222
Nood1es's Avatar
I currently have a green...for people that had a green running 30lb+ and upgraded to a red. If u had choice to do it over again, would you go hta35 or still go for the red? The multiple week wait for a red has got me on the fence.
Old May 1, 2009 | 09:28 AM
  #223
ROGERV's Avatar
Im very happy with the change to the Red. I know I can still get more out of the Red but not till I build the bottom end.
Just wait, it's worth it in the end.
Old May 5, 2009 | 06:30 AM
  #224
cij911's Avatar
Originally Posted by Davethewave
stiffer springs require the engine to do more work to turn the already havier than stock cams. its that simple
Wow, you clearly have no idea what you are talking about....The cam moves the valve and the spring controls the oscillation. Springs are selected based upon required / recommended seat pressure. Kelford and other manufacturers have recommended spring specifications for their cams. On some cams the supplier states 'recommended, but not required' - but that has to do with the ramp rates, lift, and expected redline.
Old May 5, 2009 | 08:31 AM
  #225
syktek's Avatar
