Highest HP 4g63 engine (from 2007)
Old Jun 30, 2012 | 12:01 PM
  #1906
AreSTG's Avatar
how did i find myself on nasioc? here i thought i was in the "EVO DYNO TUNING AND RESULTS" part of EvoM.
Old Jun 30, 2012 | 12:27 PM
  #1907
Yelfig's Avatar
watch it at 3:05
Old Jun 30, 2012 | 12:43 PM
  #1908
kouzman's Avatar
Originally Posted by Yelfig
excellent. Manual valve body for only manual shifts. in other words the car will not shift unless you shift it yourself. I wish we could see the incar from the launch. Something tells me that the red button on the steering wheel is the trans brake...
Old Jun 30, 2012 | 05:04 PM
  #1909
khmerpimpin's Avatar
So he's pulling the lever down to upshift?
Old Jun 30, 2012 | 05:59 PM
  #1910
batty200's Avatar
Reverse pattern manual valve body. Very common so you don't accidentally out it in reverse.
Old Jun 30, 2012 | 06:52 PM
  #1911
kouzman's Avatar
Originally Posted by batty200
reverse pattern manual valve body. Very common so you don't accidentally out it in reverse.
+1
Old Jul 1, 2012 | 08:41 PM
  #1912
Junior@TMW's Avatar
Originally Posted by juanmedina
Going from an air shifted dog box to an AUTO is downgrade why would he do that?
It seems like all you guys have 4wd 8 seconds cars, the way you guys talk make it seem like its super easy to built a 8 second all wheel drive car
A well setup auto can be much better then a seqential dog box.
The problem is the subie's AUTO's suck and very few people have got the gear box working like the glide/t400/480le etc.
Well, it is debatable. For a drag racing setup i would prefer an auto since in my opinion has many advantages:
- no need to change very expensive clutches
- very consistent shifting and launches
- on a manual you need to figure out your launch rpm, need to practice how to slip the very expensive clutch, you are risking miss shifting
- you would have to buy a very expensive straight cut gearbox for the ultimate setup
From a cost point of view you are looking at $15K easy for a dogbox and carbon clutch plus, axles, etc etc...
An automatic could be as much as half the price, plus the service intervals are much longer...
Not really, a well built auto trans for a SUBARU(key word) will cost you more then a dog box, and by the time you are done buying a proper converter.. you could have bought a triple disk.
The dog box setup in the 8sec P&L STI that I tune cost us about 8-9k
The Auto setup in the other 8sec P&L STI that I tune cost us blood sweat and tears to get it to leave and stay together. The service intervals are way more in depth and the time consuming (valve body, filters, clutches, trans brake) It does however make for super consistent times and much easier on the driveline.
Yep
If those dudes are saying the car is not an Auto, they are straight up full of ****. The car hops forward and reverse when put in gears, plus it leaves just like our AUTO GC. Next they will say it has no spray either
Jr
Old Jul 1, 2012 | 09:26 PM
  #1913
dtrackstar's Avatar
^ How can you tell he's spraying?
Old Jul 2, 2012 | 05:54 AM
  #1914
juanmedina's Avatar
Yep
Jr
We have a air shifted transmission on the electric bus where I work, the air shifted transmission can be tuned to be smooth and shift super fast.... you just need the right software and tuning . Can you imagine buying a bus that doesn't shift smoothly ?
Old Jul 2, 2012 | 09:06 AM
  #1915
Junior@TMW's Avatar
Was a joke. Since they get all mad and defensive about everything.
Just looks like it loads up on the converter/trans brake and then goes
Old Jul 8, 2012 | 12:25 PM
  #1916
ligo12's Avatar
Originally Posted by Extreme Tuners
Dynoplot from 10/2007 evo8 Vp import 1416hp
Dynoplot from 10/2007 evo8 Vp import boost vs power
Dynoplot from evo8 Methanol 31psi boost vs power (158lbs (+1700hp) turbo)
Dynoplot from evo8 Methanol ~36.7psi boost vs power (158lbs (+1700hp) turbo)
Dynoplot from ford cosworth Methanol ~35.2psi boost vs power (141lbs (+1550hp) turbo)
Dynoplot from ford cosworth N/A engine, world record from 119cui engine torque vs power in 2006.
What is going on at 5225rpm on each of these graphs?
Old Jul 8, 2012 | 01:46 PM
  #1917
Dave W.'s Avatar
Dunno, why do you ask?
Are you trying to point out that the HP plot does not intersect with the TQ line at 5250rpm?
Old Jul 8, 2012 | 02:20 PM
  #1918
Raptord's Avatar
They don't intersect because torque is measured in kg/m instead of ft/lbs and HP is measured in PS instead of HP.
Old Jul 8, 2012 | 02:38 PM
  #1919
richdegrave's Avatar
I just want to find out what that turbo does he sent out to get tested I want to know how good there product is or is it all bull**** and one big never ending post
Old Jul 8, 2012 | 04:35 PM
  #1920
yamahas's Avatar
so what happend with that turbo??
will BR ever test it or what?
i think other vendors offered to test that wheels..
