Highest HP 4g63 engine (from 2007)
Old Dec 28, 2010 | 12:23 PM
  #406
Stealthmatt's Avatar
Originally Posted by Extreme Tuners
Here are the 858lbs (9.090cc) injectors, methanol and nitro compatible. 200psi capable
we will use 4 of them and 4 of the 2450cc.
Spyros
can you tell me what RPM it will idle at and how will it idle?
so your saying ull be using 8 injectors? is there 2 nozzles on those 9000cc injectors? if so how does it all fit together in the fuel rail and cylindar?
So thats 9000cc per minute at max duty cycle?
Old Dec 29, 2010 | 12:48 AM
  #407
JDZNate's Avatar
Veteran: Air Force
Just got done reading from page 1 and I have to say, this **** is way over my head. Very impressive.
Old Dec 29, 2010 | 03:44 AM
  #408
Bramage_Dained's Avatar
@Stealth- I'm sure they use the "small" 2450cc injectors at low load/rpm and dial in the "big" injectors once load and rpm ramp up.
Old Dec 29, 2010 | 06:58 AM
  #409
derivative's Avatar
Originally Posted by GPTourer
That really is just a custom 4cyl. I think they literally just cut one of their V8 top fuel engines in half to start off with - which itself was a Chrysler HEMI design I think. So yeah, half a Chrysler engine in a RWD funny car with an Integra shell. Hmmm, okay - there's that entertainment value someone else mentioned. But its a hermaphrodite that doesn't belong to any camp, really.
Spyro's car at least uses Mitsubishi as a blue print. Domestics have done this for years as their aftermarket has them covered from top to bottom. At least now there is the option to do it with a Mitsubishi.
I didn't post the link to the Norwood Max-4 to start some sort of "well look at THIS" argument. I simply thought Spyros would have found it to be an interesting read.
Also, i think you might want to read the article before you make wild assumptions. Looking at just one of the pictures of the head would have told you its got 4 valves per cylinder, so its obviously not a hemi, its pentroof. The car is essentially one guy with a lot of ideas and the ability to make them work, much like Spyros it seems.
Old Dec 29, 2010 | 07:41 AM
  #410
GPTourer's Avatar
Okay great, it still is irrelevant to this thread.
Old Dec 29, 2010 | 04:33 PM
  #411
derivative's Avatar
Haha, nice edit there buddy. Carry on.
Old Dec 29, 2010 | 05:09 PM
  #412
milford's Avatar
This thread is absolutely astonishing.
Old Dec 29, 2010 | 07:04 PM
  #413
Aaron20's Avatar
Man is this a good thread!
Old Dec 29, 2010 | 09:17 PM
  #414
GaryChios's Avatar
Spyro,
Giasou. Exo thi to aftokinito apo palia. Orea exei proxorsei.
Anyway, you are going to have a lot of people hating on you. LOL. Keep up the good work..
I have 1100 HP and it took alot to do to make it on a 42R @ 50 psi.
When In greece this summer, I will visit.
Old Dec 30, 2010 | 02:52 AM
  #415
Extreme Tuners's Avatar
I have not much time to answer to all questions,
Derivative, yes I know this project. It’s not proper for me to compare another guys project with our. To give u an idea, we have different targets and the way that we think as matter the high end tuning. If u see from my old posts I always care about HP/per ltr. Its very important for us to obtain as much power from small efficient cc engines. It’s the most difficult and expensive way to make tuning progress. Its easy for us to make an engine with large displacement with lower rpms and boost. We don’t care.
This year that pass, we finish a 2007 project with 740hp per litter, a 2009 project with 850hp per litter, we are not satisfied. 2010 project 4g63 will finish early 2011 with 900-930hp per/ltr, that’s why we have already started the +2000hp project to pass the 1000hp per/ltr. We are not happy thinking that the BMW 1500cc destroked 4cylinder engine before 20years had 1000hp/per ltr with old school parts from the self. But, this is generally, if I analyse it more and be precise BMW at qualification rounds had 77psi to produce 1500hp, so they had 1500cc x 5,2dar = 6300cc / 1500hp = 238 per litter, and we had 2154cc x 3,2bar = 6892 / 1530 = 222hp per / ltr. But that was our 2007 project. Our 2009 cosworth engine had 2000cc x 2 bar = 4000cc / 1050hp = 264hp per ltr. with just race fuel not even methanol. And if I analyze it more with VE efficiency our 2ltr engine had 264hp at 9000rpms and F1 had 238hp at 10500rpms. So 10500/9000 = 1.16 x 264hp = 306 HP we will have at 10.500rpms with our 2009 design engine setup. And if I analyse it further if we just use the BMW F1 fuel to our engine will have 306hp x 1.18% = 361hp. That's why I tell u that we must double their HP per ltr. But although this, its shame on us to compare 2009 design with a stock 602 BMW engine from the self 25 year back, shame on us.
With the technology and knowledge that we have in our hands in 2010 we must have the double to be fair as I explain u before. But these are customers cars and we must be careful to not damage that they have pay, just for our satisfaction. We will try to make our best to brake the record without our customers project damage.
INA, no we are still working vw projects ofcourse, I will post u some pics here in my next post. We had a vw high efficiency 1870cc 16v engine ready to hit +1500 . We have this setup ready from 2007. Next post will be for u.
Bob tm, we have already tune- dyno some evo X and we have outspool the stock X turbo many times. I will post some dynoplots. We already make some custom parts and cams for these engines.
Bob tm, we have tune more than 40 evos with stock turbos with and with out tubular exhaust manifolds. There is no difference with the stock turbo. The stock turbo because of the small turbine wheel-housing no matter the exhaust manifold size-diameter-length goes to restriction. With the stock manifold we had more than 680whp and 47psi of boost.When I will have time I will tell u more about this. We have flowbench it with cylinder head installed. Its more than 2 hours writing.
Stealthmatt I will answer u to ur pm.
GaryChios, welcome.
Spyros
Old Dec 30, 2010 | 04:35 AM
  #416
The GTX3582 test is scheduled to be on Monday to the dyno to the 4g63 platform. We will try to max it out. We couldn't test it sooner on public the specific units before released. As I know early Jan will be all the line available.
We have already make an upgrade version for this, we will test it after the test of original gtx 3582, 3076 and 3071.
we have see already the gtx4202r to the dyno. There is also new 80 and 88 11blade upgrade available.
More pics on Monday with the dynoplots.
Spyros
Old Dec 30, 2010 | 06:14 AM
  #417
IrightI's Avatar
This is the best car **** ever! Thank you, and keep it coming Spyros!
Old Dec 30, 2010 | 08:09 AM
  #418
GPTourer's Avatar
Yeah, the first version wasn't as nice. I do not care that you "right" about something that is pointless.
That pretty much sums it up.
Awesome project, great work. Its great to see the platform being pushed to the limits with seemingly no budget limitations.
Old Dec 30, 2010 | 10:00 AM
  #419
dabeast's Avatar
WOW! I'm freaking amazed! Not only are your parts top notch, but look at that shop! Great work and I look forward to seeing more from you in the future. I only wish I knew of you guys 5 months ago when I visited Greece. I would of loved to stop by and checked out your shop! Well thats a great excuse to visit again right
Old Dec 30, 2010 | 10:49 AM
  #420
mkriebs's Avatar
Good work Spyros! I was fascinated by all of the technical speak, and awesome pictures! Keep em comin!!
