Highest HP 4g63 engine (from 2007)
Good point. Thanks for the insight. I just know alot of people around here swear by the T6 housings. Mainly for big V8 methanol motors using 108mm turbos though.
It needs more time to explain it better. Ofcourse big displacement engines requires bigger turbine housing and wheels. Or smaller running high boost. Or even smaller running high rpms with low boost. It's all matter size of volume at the exhaust side.
I will make a post to analyse it better
And as for the author of this thread if I read ur dyno charts correctly and correct me if im wrong but that is flywheel horsepower. And using your 18 to 23 percent loss rule for drivetrain that would put it around 800 to 900 at the wheels. Ams evo had 808 wheel horse power in 06' one year before your claim to fame. Its in the 06 issue of modified magazine. Do your research. It now has over 1200 wheel horse power not crank horsepower. Another thing is for it to be considered a world record it must be documented and witnessed by officials. If yours wasn't then its your own fault so stop complaining.
In case u didn't know this car uses one of the earlier 4g motors making that much power. The 4g in evolution 8s and 9s are lightyears apart from this motor. Their are many differences. Not to mention this is a tube chasis car fiberglass shell no interior. The ams evo is a street legal full interior car.
1. the evo 4g63 block is not lightyears ahead of nothing.. its the same **** in the dsm's. stock internals are stronger, but the blocks the same, nothing special about the block at all. same old cast iron block.
2. ams drag evo does not have full interior.. its a stripped out race car. it has the dashboard maybe thats about it.
http://www.youtube.com/watch?v=UxEgyQL4r1Q
awdordie, thanks for ur post, but i prefer from u to read my posts carefully next time.
The litle time that i have, i prefer to write technical posts or answer to serius posts from serius people.
thanks
thanks
spyros you obviously know people in f1 or are involved in f1 yourself. i'd like to ask you, how long before you see an affordable pneumatic valvetrain coming to this market?
Eddie
