Highest HP 4g63 engine (from 2007)
Old Sep 1, 2011 | 10:32 AM
  #736
CBRD's Avatar
Originally Posted by Extreme Tuners
Sure
U will not believe how this 64mm comp wheel flows, makes comon shiny 67mm wheels seems small. sorry for this but its true.
The thing is that "billet" loose the meaning when the marketing starts sell turbos.
Practicaly a billet aluminum wheel is not lighter than cast. Mostly hipped cast wheels (Hot Isostatic Pressing or HIP which is a process that subjects the wheel to extremely high pressures and temperatures 8,000 psi and 700 degrees in an inert atmosphere. This process reduces internal voids and improves the grain of the material increasing strength) are lighter than common billet aluminum. "Billet" for me is just a piece of raw aluminum stock that has been either roll formed or forged into shape, from cast the shape and blade thickness cant be done but only from 5 axis cnc and second that cast cant handle over some pressure = rpms speed - strength problems.
The mechanical properties of cast aluminum are limited as far as strength. For these reasons a cast wheel has to be designed with these issues in mind and the blades are made thicker and the center hub chunkier and stronger. So billet have smaller hub = bigger inner vane diameters but same outside diameter so moving more air per rotation and thinner blades than cast.
Thats the real meaning of it. I dont realy know why the fasion of shiny "billet" wheels came out. We use billet wheels from Ti and 7076 at least 10years when we wanted to built something special for cetrain use only. I ensure anyone that billet exact same size and shape flows like cast. We have test and test and test. Sorry from the known companies that i destroy this adv campaign and marketing issues but we dont want to lie to our customers. We built billet wheels specialy for every special test or project and for sure there is anything in cast for us.
I cant write for hours about this.....
Spyros
correct from our findings (and being educated) over the past 2 years or so with the billet alum wheels.
the slim hub has been part of the big change in the revisions with most of the new wheels out over here-
send me a PM when you are bored-
we can chat-
if on instant message- Slamdvw (dont ask) is my name-
cb
Old Sep 2, 2011 | 06:12 AM
  #737
Extreme Tuners's Avatar
More than one year of preparations and tests here is the result.
A masterpiece of quality and performance.
Just a very quick look of our +2000hp 12.000rpms dual throtle wrc/Lm intake manifold. More than one year tests of +1000hp and 2000hp intake manifolds.
Intalled and fitted with 4 x 2250cc injectors and 4 x 9250cc injectors for the +2000hp project.
Next post will be more detailed from the wrc/Lm intake manifold single and dual throtle, with flow data analysis, fluid dynamics design, more specs and from Solidworks to cnc to reality.
Enjoy
Spyros
Old Sep 2, 2011 | 07:14 AM
  #738
lekonna's Avatar
good stuff, what coils do you guys use in these projects?
Old Sep 2, 2011 | 08:03 AM
  #739
R/TErnie's Avatar
very cool. I look forward to hearing you explanation of how that intake manifold works. I suppose it solves the issue of cyclinder to cylinder flow variance of a side mounted intake manifold.
Old Sep 2, 2011 | 09:26 AM
  #740
CBRD's Avatar
Spyro-
have you experimented with individual t-bodies- we have been playing around with building some stuff- to test-
CB
thanks for the PM- definetly think we should get together on something
Old Sep 2, 2011 | 10:06 AM
  #741
BenJ's Avatar
That intake manifold is absolutely amazing!
Old Sep 2, 2011 | 12:13 PM
  #742
CBRD's Avatar
we have been looking at the jenvey stuff- its pretty awesome-
Love what you guys are doing-
cb
Old Sep 2, 2011 | 12:28 PM
  #743
wshihdnevo's Avatar
+1 Speechless!!!
Old Sep 2, 2011 | 05:16 PM
  #744
Teal2nnr's Avatar
^^ X2...unreal. Whole other level
Old Sep 3, 2011 | 01:21 PM
  #745
gsrboi80's Avatar
Fawking amazing
Old Sep 3, 2011 | 01:29 PM
  #746
dsmfan95's Avatar
It's cool to see some of the equipment you guys use and be like "hey, I use that stuff too!"
I get to use CMM's, Microvu's, Profilometers, Hardness testers, etc on a daily basis on top of my CNC work.
Old Sep 4, 2011 | 07:28 AM
  #747
MartynJeffery's Avatar
Enjoy
Spyros
Freekin awesome !
Martyn
Old Sep 4, 2011 | 03:03 PM
  #748
MrLith's Avatar
Thats just unreal. I love it! Can't wait to hear results from this setup
Old Sep 4, 2011 | 08:30 PM
  #749
Boosted Tuning's Avatar
I dont want to speak for Spyros and I may be wrong, But I believe they use Spark Tech COPs.
+1000
Old Sep 5, 2011 | 05:21 PM
  #750
JohnBradley's Avatar
Says SparkTech right in the middle of the plate.
