Highest HP 4g63 engine (from 2007)
Old Nov 2, 2011 | 04:39 PM
  #826
Elevent's Avatar
What kind of oiling mods have you done to run 11k rpms?
Thanks!
Old Nov 3, 2011 | 09:53 AM
  #827
kiggly's Avatar
You just need a cam profile and spring that will follow each other. I've bench tested my springs with the stock DSM rockers and lifters to 12.6k and short-endurance tested the setup to 11k. The 11k test was only about a 5-minute test (held at speed). Valve tip wear was an issue, but as long as the valvetrain was in control parts breakage was by no means a concern. Hold it at a speed where there is a bad surge event or take it past float rpm and everything will break.
Kevin
Old Nov 3, 2011 | 12:06 PM
  #828
gasolinebaptism's Avatar
Me being a life long DSMer can say that Kiggly is correct.
The valve train takes some engineering, but isn't a huge hurdle with the materials available.
And broken rocker arms truly aren't experienced in our DSM 4G63's.
Old Nov 3, 2011 | 01:05 PM
  #829
eTiLiKo's Avatar
Originally Posted by Extreme Tuners
tzagasdog, F1 reach 35-36m/sec for least 2 hours and 100mm pistons not 85.5mm. We reach 32-33m/sec for 20sec at a time. The pistons are designed for 36msec. m/sec, problems caused from weight and friction mostly. This engine combo tested from us many many dyno pulls and street tests. I have pics to show u what happend to a non designed piston to this acceleration if u want.
Spyros
Hi Spyros,
the average piston speed that you indicate for F1 engines is wrong. In the V10 era F1 engines have a stroke that was between 41 and 43mm. Now in the V8 era the stroke is about the same, or smaller. So, assuming a stroke of 43mm at 18.000rpm, it translate into 25.8m/s.
Also if we consider the 20.000rpm revlimit of the 2006 season, it will be 28.7m/s.
Andrea
Old Nov 3, 2011 | 03:58 PM
  #830
Originally Posted by eTiLiKo
Hi Spyros,
Andrea
Want to calculate maximum speed now? And get rid of dead time at TDC and BDC and the acceleration after each?
I'm saying that you may be right with "average speed", just that Spyros didn't quote "average speed"
Old Nov 3, 2011 | 04:04 PM
  #831
dtrackstar's Avatar
i'm guessing andrea is from a rival shop in greece.
Oloi aderfia hmaste
Old Nov 3, 2011 | 04:13 PM
  #832
Yea, who pencils out some math with the sole intention of proving someone, that is very beneficial to R&D at the consumer lever, wrong?
Old Nov 3, 2011 | 04:29 PM
  #833
JohnBradley's Avatar
Aaron, here in Greece pump gas is ~100octanes. Its tuned till 14psi with this.
Thank you. I like the look of your control in the ECU you developed. I can have a lot of fun with that.
Aaron
Old Nov 3, 2011 | 04:51 PM
  #834
Broham's Avatar
that ecu program is a gamechanger. Hopefully its not 8k
Old Nov 3, 2011 | 06:08 PM
  #835
ssg_petty_210's Avatar
Might be the highest HP car, but those times are not the fastest nor the trap speeds.
Old Nov 3, 2011 | 07:25 PM
  #836
Teal2nnr's Avatar
^^^ oh ya, at 14 PSI that's horrible lmao
Old Nov 3, 2011 | 07:56 PM
  #837
binky's Avatar
If you read the thread, they didn't build it to be the fastest, they built it to be the highest HP.
-Bink
Old Nov 3, 2011 | 09:23 PM
  #838
I read most of it. But yeah gotcha.
Old Nov 3, 2011 | 10:05 PM
  #839
binky's Avatar
Word
-Bink
Old Nov 3, 2011 | 10:54 PM
  #840
tscompusa's Avatar
I cant stop watching this video; http://www.youtube.com/watch?v=IYaqskg3Wh0
its amazing how smooth that car can shift even at 11,000rpm+
I was in a vehicle about 3 weeks ago with a STM (New Zeiland) Dog box + Ghost shifter with an Ikeya sequential shifter (up and down clicks to shift).. they call it a ghost shifter because theres a button on the steering wheel you push and it shifts to the next gear for you.. but that car was brutally aggressive as far as shifting went.. it was very loud and shifts came on hard.. it seems in this video its shifting like butter and hes not even using the clutch pedal.
pretty amazing.. then the fact its 14psi.. pretty much the turbos so big that it shifts the powerband to the 2nd half of the rpm gauge . i was in another car that had a powerband similar to that. its amazing when youre just normal shifting around town at 6500rpm and it feels like 3000.
