Highest HP 4g63 engine (from 2007)
Old Nov 5, 2011 | 05:34 AM
  #856
EugeneSAN's Avatar
Can you tell me please what kind of gear box you use and what gear ratios and final gear ratios!
Can you tell me how it can be on 4th gear 145miles and 11000rpms from the video????
Thanks beforehand!
Old Nov 5, 2011 | 06:00 AM
  #857
YaroRS's Avatar
Old Nov 5, 2011 | 10:05 AM
  #858
MartynJeffery's Avatar
Originally Posted by claudiumxg
nice ecu, similar to what i use
and it has been around for almost 20 years now ......
We use it too, mapped a couple of 700bhp Imprezas on it fairly recently.
Martyn
Old Nov 5, 2011 | 10:18 AM
  #859
JohnBradley's Avatar
I just noticed that the pistons have 1 ring. Tried this in Pro-stock years ago and while it worked it made starting a cold motor a little more difficult. Spyros are you running a thicker ring to compensate or less gap?
Old Nov 5, 2011 | 10:28 AM
  #860
Boosted Tuning's Avatar
What ECU is it?
Old Nov 5, 2011 | 12:04 PM
  #861
Originally Posted by Boosted Tuning
What ECU is it?
Life Racing or Syvecs.
Old Nov 5, 2011 | 12:24 PM
  #862
claudiumxg's Avatar
at origins pectel(with pectel developer you can make your customised interface..)- this most probably syvecs/liveracing -very good but also very complex.....
ps. Martyn, i really like that injector on the intercooler pipe
Old Nov 5, 2011 | 02:49 PM
  #863
Thanks. Checked em out. Looks like great stuff.
Old Nov 5, 2011 | 05:41 PM
  #864
Lol, I take it you mean on Paul Doyles Time Attack car, can't rake the credit for that one i'm afraid, Mr Blamires work that one
Martyn
Old Nov 5, 2011 | 06:14 PM
  #865
Lol, I take it you mean on Paul Doyles Time Attack car, can't take the credit for that one i'm afraid, Mr Blamires work that one
Martyn
Old Nov 5, 2011 | 11:52 PM
  #866
claudiumxg's Avatar
Martyn
combo made by zen performance?,
any way not to go off topic, the ecu extreme tuners use is very powerful but takes quite some time to get used to it, not friendly to a end user like other plaforms, but configurablre to any extent
Old Nov 10, 2011 | 11:13 PM
  #867
BlownIncome's Avatar
[QUOTE=tscompusa;9720329]I cant stop watching this video; http://www.youtube.com/watch?v=IYaqskg3Wh0
its amazing how smooth that car can shift even at 11,000rpm+
Sweet Beautiful Mother of Baby Jesus!!! Me likey
Old Nov 11, 2011 | 09:46 PM
  #868
evoracingstar's Avatar
crazy
Old Nov 13, 2011 | 04:25 AM
  #869
user 72082032's Avatar
Originally Posted by Extreme Tuners
As u can see the difference just making the engine little more efficient is dramatically different. My 4g63 engine running 133% Vol eff. and the best point is when i boost it the mechanical efficiency stays the same but the volumetric goes double or triple or any boost pressures i desire goes x (boost pressures).
A quick explanation of engine Vol Efficiency = cylinder heads job, how quick the engine can burn the mixture per a certain time period. How we can moving masses from the same displacement.
Spyros,
Great thread and nice to see someone finally fitting modern parts to these old engines.
A quick question. How are you deriving you VE data? I see you use a chassis dyno and i see no airflow turbine. Did you also use an engine dyno for development? Personally i do not trust the airflow turbine because some of its measured flow is blowing straight out the exhaust.
For my own use i have tried to work out VE from logging lambda and injector pulse width then calculating back the air volume. Just curious how you have done it.
Tim
Old Nov 15, 2011 | 07:43 PM
  #870
1SloEvoNoob's Avatar
damnnnn i got some catching up to do after selling the evo a year ago....i loved this thread
