Red vs Black on Pump
Old Dec 15, 2009 | 07:00 AM
  #136
460hpevo8's Avatar
Originally Posted by yahu
I don't think that old avatar pic would fit in an Evo!
What's going on with your car, CA$H?!
what do u mean "what is with my car? Is this thread about johnbradley or about my car?
Old Dec 15, 2009 | 07:27 AM
  #137
Evo8=Life's Avatar
Great test
Old Dec 15, 2009 | 02:34 PM
  #138
CA$H's Avatar
Same old... I need to do a WGA swap but, Haven't even messed with it. I think I want the Black tho cuz I would like more hp and tq. man... I got geared up when I thought I was going to get 500/500 and it didn't happen. wull see
Old Dec 15, 2009 | 08:47 PM
  #139
yahu's Avatar
Haha - CA$H is another username on here, so sorry about the confusion. I'd call him by his real name but that would likely confuse people more and he may not want it blasted all over the forums.
Old Dec 15, 2009 | 08:50 PM
  #140
yahu's Avatar
Ah, that is where you were last we talked. You need to make one of the meets, buddy! We had like 5 this past weekend! Phew!
On the exact same tune, same fuel levels, same boost, etc., the Black was good for ~+30whp on pump gas! We could've pushed it more with 100% meth but honestly on the stock block there was no need to.
If I don't speak to you beforehand, have a happy holidays!
Old Dec 15, 2009 | 09:37 PM
  #141
AngryEvo8's Avatar
Ok...back to the thread at hand.
Is a aftermarket intake manifold a must when running pumpgas with the black? Or would porting be sufficient?
Old Dec 16, 2009 | 08:12 AM
  #142
BLKCarbonEVO's Avatar
^ It is not a must. But the large Magnus v5 really helps out a lot. It is on of the best mods you can do imo.
Old Dec 16, 2009 | 09:19 AM
  #143
JohnBradley's Avatar
The Magnus or any of the available aftermarket intake manifolds allow the engine to breathe easier (increased VE) and as a result we can run more timing on a given combo.
On my personal car on the stock intake manifold I couldnt run more than 9* at 29psi on pump and was limited to around 530whp. More boost or more timing only resulted in misfires and knock. I swapped to the the Magnus cast that is on my car and was able to run the timing up to 12-13* and over 30psi without knock. I was making 575 then at 29psi. The power was the timing that I was able to run but you can see a definite divergence in the powerband of my car after the intake in general.
Past around 7k it really started to take off, this is a combination of the intake and timing as I mentioned.
Old Dec 17, 2009 | 09:39 AM
  #144
Mellon Racing's Avatar
very good info in this thread, thanks for sharing
Old Dec 23, 2009 | 03:33 PM
  #145
Evo_Jay's Avatar
What about porting on the turbos? Was the RED and/or the BLACK ported?
Old Dec 23, 2009 | 06:09 PM
  #146
wizzo 8's Avatar
Is there going to be red vs black dyno sheets for 93 with meth? Or is this in another thread?
Old Dec 23, 2009 | 06:52 PM
  #147
Both turbos were left unported.
The red numbers previous to the black were 470whp/380tq on 100% and the car made 512/413 on the black at the same boost level. I will try to get the dyno sheet from Drift Office from our last dyno day there so we can compare the two.
Old Dec 23, 2009 | 06:59 PM
  #148
Evo_Jay's Avatar
Thanks for the answer.
Old Dec 27, 2009 | 08:39 AM
  #149
batty200's Avatar
INCORRECT totally. The best that has been done on a DJ is 565whp from 9sec9 on Swytzer's dyno.
Quick question, didnt Most Wanted do over 600whp on a dynojet on a Red? I was fairly sure that was the "record" for a red on a DJ.
Old Dec 27, 2009 | 11:22 AM
  #150
You are correct, I just found the thread as well:
https://www.evolutionm.net/forums/ev...ml#post6653188
