Virtual Dyno is available!
Old Jun 30, 2010 | 04:26 AM
  #61
tscompusa2's Avatar
ya that def sounds like you hit the max it can read. i wonder what youll make with sd at 38psi lol. what HP per psi do you normally make? like 25? how much you plan on pushing the new motor to? i think 700~ dynojet is more then enough to kill your entire state plus the surrounding states LOL.
Old Jun 30, 2010 | 04:44 AM
  #62
3gEclipseTurbo's Avatar
Originally Posted by Mellon Tuning
I have a 10:1 CR motor on the way back from Buschur and I'll give the stock MAF one more try. Last time out it did 705 at 38psi and 715 at 45psi, clearly I'm hitting a wall there. I sent the head in for inspection too just in case there was some valve float causing that. When I raised the boost the tq shot up from 540 to 609tq so at mid range the boost helped tremendously.
If I hit the same wall, I'll try SD and if the power jumps way up, we'll know without a doubt the upper limit of the stock MAF
Even though I disslike him Al hit 815whp I believ with a stock port/valve size head. Its probably just valve float, or something besides the head restricting air flow above 38psi.
Old Jun 30, 2010 | 05:10 AM
  #63
Mellon Racing's Avatar
I agree, the BR stage III head will not in itself be the limiting factor
Old Jun 30, 2010 | 10:05 PM
  #64
bbarnhill's Avatar
1.0.0.2 is close ... its been sent to some people to test and once they come back and let me know if its working ok for them, then its going to be posted.
Thanks for being patiently waiting for the RPM trimming feature. Tire size calculator is coming up next (I think).
Old Jul 1, 2010 | 07:48 AM
  #65
the new version is up, see first post for the link
Release Notes
1.0.0.2
- Column names are now an editable item under options
- An RPM trim feature has been added to allow trimming of the run
- Dyno specs are now shown on the graph
- Added 00-05 Eclipse 4g64 (5 Speed)
- SAE correction default was changed to off
- Fixed a bug where the range of the Y-axis were figured wrong on the HP/TQ graph
- Corrected some of the cars.xml data
- Running on .NET Framework 3.5 now (including 2.0 in VS2010 was highly discouraged)
- Installer now checks for framework being installed and installs if not present
1.0.0.1
- Evo IX MR (6 speed) added to the car parameters file
- Evo IX RS (5 speed) added to the car parameters file
- Evo X MR (6 speed) added to the car parameters file
- Fixed a bug with the application not finding cars.xml
- Corrected some Evo VIII weights and gear ratios
- Corrected some Evo IX weights and gear ratios
- Car dropdown list is now sorted by car name
- Ability to donate(paypal) has been added to the help menu
1.0.0.0
- Initial Release
Old Jul 1, 2010 | 12:28 PM
  #66
Boosted Tuning's Avatar
DL'ed the new version. Found a problem.
When trying to eliminate spikes at the end of the run using the rpm trim feature, it trims the RPM fine and makes the graph correct, but the HP/TQ numbers stay at the incorrect number that the spike went to.
Old Jul 1, 2010 | 01:23 PM
  #67
Mike01gsr's Avatar
+1 got the same issue!
Old Jul 1, 2010 | 01:57 PM
  #68
MR Turco's Avatar
hey guys, can we keep the bug troubleshoot and support in the ECU flash thread.
Thanks!
Old Jul 1, 2010 | 04:56 PM
  #69
good eye guys, I had a funny log where the tq line was higher than the hp but the numbers below were the other way around. I bet its the same problem. I reported this directly to Brad so he's aware and looking into it.
Old Jul 1, 2010 | 05:08 PM
  #70
Thanks!
Maybe the two threads should be merged? Or this one closed and we can use the other?
I think its silly with the same two threads.
Old Jul 1, 2010 | 08:17 PM
  #71
bbarnhill's Avatar
Ive figured out the Max HP and Max TQ after trimming problem ... that was honestly a brain fart on my part. Bear with me. I have those regularly. Ill post an update VERY shortly.
Old Jul 2, 2010 | 10:02 AM
  #72
the new version is up, see first post for the link. This release should be very functional now, the big issues have been resolved and now Brad can work on features
Release Notes
1.0.0.3
- Trimming now shows the correct MAX HP and MAX TQ numbers after trimming is performed
- Trimming now adjusts for the correct Max RPM
- Redundant code was taken out of the point calculations
- Restructured how Max values are determined
- Removed unused resources in the project to shrink final binary size
- Increased smoothing levels to 30
1.0.0.2
1.0.0.1
1.0.0.0
- Initial Release
Old Jul 2, 2010 | 08:27 PM
  #73
Redline06's Avatar
Originally Posted by *constant_boost
chris, can you email me the program? I cant download from sites on this computer. only emails.
Just wait till you get back, what is the rush..? what are you going to do.. DYNO MATV's and MRAPS...lol
Old Jul 2, 2010 | 08:45 PM
  #74
Old Jul 12, 2010 | 09:27 AM
  #75
brad is putting the finishing touches on 1.4, it's coming along nicely
