CBRD new BBKB results
Old Dec 2, 2010 | 08:47 AM
  #436
TURBevO8's Avatar
I would love to lay down 430 on CBRD's dyno but really I think I want to just tip the scale toward the "big turbo" side and whatever that yeilds, it yield. Meaning go as big as I possibly can while living with the extra lag and lack of response to a well defined point. Almost like going to the perfect turbo as far as response then going just one step up. Example, I know a 35R is not for me but a BBK Full is so good I could live with some more lag if need be. I drove one once and it felt like it spooled FASTER than my stock VIII turbo. When I was younger the car was build purely for the twisties. Now that I am older and not as crazy out there I kind of want something more for the straight line but still very DD-able. I think this will be the ticket.
So where are all the results???
Old Dec 2, 2010 | 09:43 AM
  #437
wally7714's Avatar
Originally Posted by evo8 951
Thanks chad. Im really interestd in this. My plan is to use my oem upper i.c. Piping, stock block and head besides cams. I will have supporting bolt ons. Im glad i didnt jump on the hks just yet. Lol
I`ll be buying turbo in a next couple of weeks. Still not sure between HKS 7460 vs BBK Full. HKS BB spool is tempting but id doesn`t flow as good as BBK and cause of that HKS might suffer form Surge. Well I`ll have some $$ in couple of weeks, I should decide by then
Old Dec 2, 2010 | 06:35 PM
  #438
Evolutionn's Avatar
bbk=nice I just dont know about the oem center sections. Is it just a stock turbo with new wheels?
Old Dec 3, 2010 | 04:51 AM
  #439
TURBevO8's Avatar
No. The bearings are upgraded too.
Old Dec 4, 2010 | 06:22 PM
  #440
OZEVO9's Avatar
Results from last week on Evo9 from Australia running usual mods,
E85 on 24psi..Soon to be run on the dyno with higher boost..
Anyway here's the YouTube links and Dyno Sheets
http://www.youtube.com/watch?v=psuEcm6ythw
http://www.youtube.com/watch?v=yeQ7vzJADGo
Old Dec 4, 2010 | 07:47 PM
  #441
deebo3726's Avatar
whats the diffrence in spool between the bbk b and the bbk full?
Old Dec 4, 2010 | 08:21 PM
  #442
OZEVO9's Avatar
I don't know what the difference is in spool time to the BBK Full as I upgraded from stock turbo, but in previous post i think someone mentioned it's around 250rpm, and about 450rpm from stock. My choice in this turbo was based on future mods, and that I will require a stroker kit to make this turbo work well. It is my understanding that this turbo needs 26psi or more to be doing it justice. My tuner advised that he would tune it on 22psi & 24psi for now, then bring it back in a few weeks to up the boost.
Considering the low boost setting, I am thrilled to be making 400whp, I really would like to see what the stock 2.0ltr can achieve. Starts spooling at about 3600, and the power delivery is very strong from 4100 right up to the top end range of 7500. I can say that there is so much more in this turbo to come, when I have completed my objectives. The car has been reborn Great work CB
Old Dec 4, 2010 | 08:33 PM
  #443
deebo3726's Avatar
impressive spool near identical to bbk and more power....id like to see a comparison with the fp green and bbk b
Old Dec 4, 2010 | 09:57 PM
  #444
06MREvo's Avatar
Right around 400whp on only 24psi...not too bad...haha its so weird to look at a dyno sheet in KW...
Old Dec 5, 2010 | 01:20 AM
  #445
OZEVO9's Avatar
Over here we have kilowatts, and I am told this dyno reads low, so it could actually be a higher reading. I will keep this thread updated
Old Dec 5, 2010 | 01:48 AM
  #446
FQ4OO's Avatar
Based on the intake temp you more than likely had a correction factor to your advantage so if i was you id be happy with the power reading and not assume the dyno is low.
Nice result BTW, pretty good response for the power output.
Old Dec 5, 2010 | 07:55 AM
  #447
TURBevO8's Avatar
I know most guys run the Full at 26-27psi on 93 and it seems this turbo picks up 30 or so whp on the same boost on the same fuel for a trade off of 250-300 RPM and a bit of transient response loss. Think back to when we all did cams the first time...it was about the same gain with the same loss. Only here the B is the same price (basically) as the Full so it is like getting 30whp for free. I have been back and forth on this so many times...stock IX, Full, or B. With the supporting mods I have or will have on this winter, I am going with the B. I finally made up my mind. God, I cannot wait till spring! lol
Old Dec 5, 2010 | 08:00 AM
  #448
vmrevo9's Avatar
Veteran: Air Force
Definitely not a bad choice. I plan on adding more to my setup to really take advantage of the full. Then whenever it's time to rebuild the motor it will probably be built to suit the B. Well that's the plan anyway.
Old Dec 5, 2010 | 09:21 AM
  #449
TURBevO8's Avatar
Yeah I guess what really got me to this point is we have a baby on the way and I know the chance of me upgrading from the Full to the B, or anything else for that matter, anytime soon is not gonna happen. So figured I will just go all out now...while I still can...
Old Dec 5, 2010 | 02:45 PM
  #450
vmrevo9's Avatar
Veteran: Air Force
Congrats on the baby!! Might as well go all out now like you said. I will eventually upgrade I hope if not no biggie. I still need to upgrade the intake manifold and TB as well as the intercooler. I think I'll play with this setup and try to max it out then see what I can do with the B!
