Spec Ops + Tab-Fab HTA3586 on 93 octane!
Old Nov 24, 2010 | 06:25 AM
  #91
kidtsi's Avatar
Now e85 and turn the boost up.
Old Nov 24, 2010 | 07:21 AM
  #92
Spec-Ops1's Avatar
he has injectors... there just isn't a lot of E85 around us to justify the change as of yet.
There are a lot of ways he can go with this setup, and there is some potential in it for sure.
Old Nov 24, 2010 | 01:27 PM
  #93
crewdawg130's Avatar
Originally Posted by Jason@Spec-Ops
NVM...
I just cant think of anybody, not w/o having an .82 on it
Jason. no one other than Jeo had .83s. Remember Justin before he sold the turbo (on pump) when you where gone. Remember the evo that justin sold the kit to.... remember troung (built engine though).
This is just to answer your question. Im not trying to take ANYTHING away from this. Again, good on yall. Later on this thing is gonna be beyond nasty. This is by far the best turbo for over all power.
Old Nov 24, 2010 | 01:42 PM
  #94
Spec-Ops1's Avatar
those were all .82 hotsides.... justin's was, truongs was, they were all .82s. Mine was the first .63 hotside that we used. You should remember because everyone was cracking on me for using a smaller hotside. I'd imagine the hotside didnt change when justin sold it, so Daves car has an .82 as well. If somehow their .82s shrunk, then i'd be embarrassed by the spool as my .63 hit 28 psi by 4600 and they didnt hit it until 51 or 52 which is consistent with the .82 especially when compared. So to agree with your statement, Seeing 500whp on a standard 35 w/ .82 hotside is fairly common... the .63 however is not something so common which is why i asked who you were talking about when you made the comment because i still cant think of anyone that came close on pump gas.
Old Nov 24, 2010 | 01:49 PM
  #95
EvoFlash's Avatar
This setup should have a lot more in it . I made 491whp@ 28-29psi on a dj with my hta3582 with a .63a/r and pretty much same mods except I had kelfords. On pump gas.
Old Nov 24, 2010 | 01:59 PM
  #96
Spec-Ops1's Avatar
Timing ? AFRs ? 93 ?
We know it has more in it... we also know the DJ reads a little different than most others.
Old Nov 24, 2010 | 02:10 PM
  #97
EvoFlash's Avatar
Not sure on timing been a while since this setup has been gone and yes on 93 and afr 11.4-6
Old Nov 24, 2010 | 04:38 PM
  #98
No worries sir. Im getting the red evo back in a week and ill post the pic. just to avoid confusion.
Old Nov 24, 2010 | 05:11 PM
  #99
JohnBradley's Avatar
27.7psi on a 2.0L with the .82 will be just under 530whp on 92 octane on a dynojet with those mods.
It does give up almost seemingly a 1000rpm of spool for that 100hp but its all about whats important to you I guess. When you compare where the 2 setups make 300 ft lbs though that gap shrinks to around 500rpm.
Old Nov 24, 2010 | 05:18 PM
  #100
Originally Posted by Spec-OpsMotorsports
Bobby, there is plans in the works to do more work on Ali's car in the future, which afterwards he'll feel more comfortable getting aggressive with it. As said before, he drives it so damn much that on the stock block he doesn't want to push it.
As far as the .63 on the other 35r's that were on those other cars in the past, I know meth was on Jason's when it made the power it did. What mods were added to the others over what Ali's car has on it now?
I TOTALLY understand about alis car. ... no questions about it.. yes she got way more in it and in time shell get it.
Justin's car was just cams and the kit. We tuned it on pump after we hit 500 on pump on Troungs just to play with it. we broke 500 and we stoped. Right after he sold the kit to a stock evo9. we put 272s, 1200cc and the kit. hit 510 or 514 just cause the owner wanted to push her and he dint care. obviously we pulled it back to a lower boost and he took it. theres also 2 more from out of town. stock blocks also.
Also, we need to get off this hotside talk and get back to Ali's. we can make a thread about it.
Old Nov 24, 2010 | 05:23 PM
  #101
Spec-Ops1's Avatar
Whats going on JB, long time no speak.
Typically what do the .63 hotsides you tune spool at with a 35?
Old Nov 24, 2010 | 05:30 PM
  #102
Below is the for sale ad for the guy i sold my 35r kit to, conveniently after he checked it over, he found an .82 as well. So from the time i bought the car from Truong, i must have installed an .82 in it ?
Peakboost gt35r .82 turbo kit
rodger, i guess well never know. Cant even compare anyways on a built bottom with a JAM head. So no factor like i mentioned the first time i talked about troungs
Old Nov 24, 2010 | 05:45 PM
  #103
Well there is a difference between spool and where it makes 300 ft lbs for a given boost level. Most of them will light off on an VIII around 4600 or so (300 ft lbs) but make decent boost by 4200-4300.
Old Nov 24, 2010 | 05:50 PM
  #104
Spec-OpsMotorsports's Avatar
Originally Posted by Force-Fed Performance
See you guys around town sometime.....
I look forward to seeing you also.....
Thanks for posting this info JB.....
I agree. I would like to see people post their mods and dyno graphs, even VD/VDR graphs, in a seperate thread so we can see more info between the 2.
Old Nov 25, 2010 | 03:36 PM
  #105
Smike's Avatar
Thread -- stay on-topic of this car.
