IX Stock Block, 64mm Red, Boltons
Old Apr 20, 2011 | 09:29 AM
  #106
High_PSI's Avatar
Originally Posted by raasfaas
I should have done a backup 4th gear pull to confirm that it was legit, maybe my mbc acted up on that pull, but time did not permit.
454tq is definitely out of my comfort zone on the stock block...+ I much prefer to try holding a flat boost curve vs a hard spike and taper off.
Either way it'll taper off to the same amount. These stock frame turbos can get a LOT of power under the curve. That spike again is half the benefit. Torque really make syou move man.
Old Apr 20, 2011 | 02:38 PM
  #107
raasfaas's Avatar
Yea I know what you mean, this thing moves!
gonna do a few checks and get back on it.
Old Apr 20, 2011 | 03:28 PM
  #108
L'orenzo's Avatar
Yea I hope so too, if all goes well it should...
It sucks that they cancelled the meet though, now it's been pushed back well over a month...we might be arranging a tnt session with Windsor so I may get to run before the official meet.
yea tru dat cause i was really looking fwd to see what times ur evo wud run and luez evo to see if it wud run 8
Old Apr 21, 2011 | 05:52 AM
  #109
raasfaas's Avatar
I heard that they will still have the timing equipment working on that day so competitors can still come and run their cars (just no trophies or money at the end)
Old Apr 23, 2011 | 09:32 AM
  #110
s.e.a.n.'s Avatar
just book a flight to come home for the weekend then
The upgraded actuator should get you a pretty nice boost curve when properly preloaded, but don't go overboard with it or you'll start to experience boost creep.
When do you see full boost by?
I wish maybe summer. Not sure. Went to PBIR last night best time was 11.9 @ 120 same ET as last yr put more mph. The laptop died on me so I couldn't raise the 2 step or the limiter.
Old Apr 28, 2011 | 10:14 AM
  #111
stabiemcstabin's Avatar
Just curious I see valve springs and retainers, r u running stock head studs to ?
Old Apr 28, 2011 | 02:28 PM
  #112
raasfaas's Avatar
Originally Posted by Boostn2g
Same question here
Yea my bad, forgot to add that...ARP headstuds
Old Apr 28, 2011 | 02:30 PM
  #113
raasfaas's Avatar
Well more mph is always a good sign...what were you launching at and what were your 60's?
With the power you're making I'm sure you've got a mid 11 in there.
Old Apr 28, 2011 | 02:38 PM
  #114
s.e.a.n.'s Avatar
Its set at 6k, the 60ft on that run was 1.8.
Mid 11s will some with more practice.
Old Apr 28, 2011 | 07:39 PM
  #115
raasfaas's Avatar
Yea I get ya, pretty good time tho...juss for reference I've got my 2 step set at 6300rpm with about 20psi all around...gets me low 1.7 to high 1.6 60's...are you running the launch maps? how much boost you seeing off the line?
Old Apr 29, 2011 | 05:41 AM
  #116
s.e.a.n.'s Avatar
No we haven't really messed with the launch map...**** i didn't even change the tires pressure 30psi at all 4 corners
Old Apr 30, 2011 | 05:48 AM
  #117
raasfaas's Avatar
there you go...you're just a drop of the tire pressure away from mid 11's
I build about 12-13psi off the line with my launch maps.
Old Jun 30, 2011 | 07:51 AM
  #118
L'orenzo's Avatar
Any updates from the last time the car ran?
Old Jun 30, 2011 | 08:09 AM
  #119
raasfaas's Avatar
Yup: https://www.evolutionm.net/forums/ev...s-rnd-2-a.html
Old Jun 30, 2011 | 08:10 AM
  #120
LGshow19's Avatar
He has a new thread up...
